Old 03-12-2013, 02:06 AM   #1
njccmd2002
Toyota Freak
njccmd2002's Avatar
Drives: Whiteout FRS
Air conditioning Moldy smelling
this issued plagued the camry, and now i think its haunting me.. anyone with the same problems, my car only has 1600 miles.
njccmd2002 is offline   Reply With Quote
Old 03-12-2013, 02:19 AM   #2
fistpoint
Drives: Supercharged Golf Cart
Cabin filters smell weird sometimes. Check it out.
fistpoint is offline   Reply With Quote
Old 03-12-2013, 02:23 AM   #3
ahausheer
Re-member
Drives: Toyota camry
Same problem but on a different car. Previous owner never turned recirc off, I think that was the main issue for some reason. Also, if you haven't already, make sure the AC drain hose is not plugged up. Otherwise look online, there are antiseptic foams that you spray through long thin hoses into the heater core to kill all the nasty stuff or try a bunch of Lysol into the vents.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 03-12-2013, 10:13 AM   #4
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
in the owner's manual, it says the smell is normal.
chenshuo is offline   Reply With Quote
Old 03-12-2013, 10:16 AM   #5
FRiSson
Drives: FR-S MT
Don't use one of those spray desanitizers. They make your car smell worse than those pine tree fresheners. You should run your air conditioner for a few minutes every few days to keep the seals lubed and to prevent stale water from accumulating.
FRiSson is offline   Reply With Quote
Old 03-12-2013, 10:25 AM   #6
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Might also try cranking your heat to max while running the AC for a while. If there is mold it could kill it.
blu_ is offline   Reply With Quote
Old 05-08-2013, 04:02 PM   #7
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
Were you able to find a solution? I just bought my BRZ and the damn A/C reeks. To the point I am considering trading in the car.
DoctorNick is offline   Reply With Quote
Old 05-08-2013, 04:04 PM   #8
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I think the filter for the AC is in the glovebox... Take a quick look in the owners manual and it will show you where to go. This may help you out as you can directly smell if the filter truely is the cause.
Subaru STI :
Old 05-08-2013, 07:31 PM   #9
Mikem53
Drives: FR-S 6MT
The simple fix is to turn off the compressor, turn off recirculate for a few minutes before you turn the engine off. This helps remove the moisture from the vents and plenum so you don't get that musty odor and mold build up..
Don't use sprays and junk in there..
Mikem53 is offline   Reply With Quote
Old 05-09-2013, 08:32 AM   #10
njccmd2002
Toyota Freak
njccmd2002's Avatar
and most of you are right, to prevent it from happening.
but once the problem starts its freaky annoying... a/c service from toyota is 150 in my area.
I solved the problem in the camry with see below. I might just do that with this one, summer is coming...... 35 buks...
Old 05-09-2013, 11:14 AM   #11
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
turn off recirc...
Originally Posted by Marchy View Post
and then at the suggestion of the mazda tech, would use recirc for the last few minute of my commute.
turn on recirc...
which one is it?
anyways, i had the same issue in our outback - recommendation was to turn OFF recirc for the last few minutes of driving, and always turn off the AC and leave recirc off before when shutting off the car.
here's an article:
http://suite101.com/article/bad-smel...tioner-a134728
shiumai is offline   Reply With Quote
Old 05-09-2013, 12:04 PM   #12
AznBRZer
Drives: 16 CBS WRX Limited
As with every other car, you're supposed to turn off the A/C for the last 5-10 minutes of driving and run the fan with the vents open(re-circ off) to evaporate any condensation caused by the A/C.
AznBRZer is offline   Reply With Quote
Old 05-09-2013, 07:38 PM   #13
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Follow this and your car won't smell. 5-10 may be a bit long, just maybe a few mins before you get out of the car, just run the vent only without AC.
CamryDS is offline   Reply With Quote
Old 05-09-2013, 08:15 PM   #14
wheelhaus
wheelhaus's Avatar
Originally Posted by shiumai View Post
turn off recirc...
turn on recirc...
which one is it?
here's an article:
I think the idea is to use both recirc and external air to ensure no inlet pipes are collecting moisture. If you primarily use one, switch to the other a few minutes before shutdown.
wheelhaus is offline   Reply With Quote
Delete of Air Conditioning 000 Racing Engine, Exhaust, Transmission 27 07-03-2016 11:26 PM
WTB: Air Conditioning Condenser - Drats! cobrabyte Miscellaneous 3 03-20-2013 09:29 PM
