Old 03-12-2013, 02:41 AM   #1
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open
I'm getting this CEL while running hard on the track.
I've cleared it several times and it keeps coming back.
Anyone else seeing it?
Any known fixes?
romin is offline   Reply With Quote
Old 03-12-2013, 02:54 AM   #2
Visconti
Drives: 05 STi
You running a unichip?
Visconti is offline   Reply With Quote
Old 03-12-2013, 03:01 AM   #3
romin
romin's Avatar
I've gotten this CEL both with and without my tune.
The engine seems to be running fine otherwise.
Using a prior "older tune" I did get some misfires and the CEL in question.
Old 03-12-2013, 09:17 AM   #4
mad_sb
Drives: 2013 Asphalt FR-S
remove the unichip and see if it goes away... interceptors can make sensitive monitors very unhappy. If you put it back to stock and still have the issue then you can at least rule out the unichip and start looking at replacing the coilpack etc.
Old 03-12-2013, 10:06 AM   #5
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Were you tracking with a unichip or ecutek tune?
Old 03-12-2013, 11:38 AM   #6
romin
romin's Avatar
I don't use or have a Unichip.
My car does have an EcuTek tune and the CEL first showed up while the tune was installed. I have since removed the tune, back to stock, and was able to reproduce the CEL but only on the track running hard.
Old 03-12-2013, 11:41 AM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Any known fixes?
Mine gets it also, completely stock ECU. At the dealership for a coil pack replacement right now actually. I'll see in a few weeks if it fixes it when I'm at the track again.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-12-2013, 11:58 AM   #8
ATL BRZ
ATL BRZ's Avatar
hmm are we uncovering a coil pack weakness or defect?
Old 03-12-2013, 12:23 PM   #9
romin
romin's Avatar
Did the dealer jump straight to the coils or did they check the plugs first? I'm wondering if we should be running a cooler plug on the track.
Old 03-12-2013, 12:43 PM   #10
mad_sb
My Bad, sounded like you were saying you had one, but zeroed it out.
From a quick look at the manual it may be an overheating problem with no. 1 coil pack:
Old 03-12-2013, 01:27 PM   #11
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
tuned in to this thread..this sorta thing, potential for warranty replacement can worry the FI consumer..my audi went thru a coil pack recall, but no aftermarket FI stuff there
what is the intelligent way to see if a colder plug works better(whatever that is to a coil pack)or provided 'benefits' short of my paying a tuner to run dyno and some exh gas analysis? is this cause we're boosting and tuning? I doubt its the plugs so early on, but ya never know, if its happening with OE tuning, then there maybe something there in the way of breakage potential we have uncovered, is it a call to carry a spare?
I'm curious to know what the dealership finds/replaces
Huehuecoyotl is offline   Reply With Quote
Old 03-12-2013, 01:45 PM   #12
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Stumbled on this thread while searching...
Just picked up my car from the dealer after throwing a CEL. Dealer said the car was throwing an ignition related code. Coil pack on one bank replaced + dealer ECU reflash = problem solved so far.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 03-12-2013, 02:13 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Well technically they started the warranty claim off my picture of the code scanner, so they didn't see the car until this morning after the parts already arrived. I'm not sure what they are specifically checking first today.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-12-2013, 05:44 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
OK so they replaced the Cyl 1 coil pack.. I'll see if it happens again.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 06:29 PM
