Old 03-14-2013, 01:51 PM   #1
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Oil sump?
So I am a car noob but I have friends with experience. I was discussing mods and one item I was asked about was an oil sump. Having not seen any threads go by on this I thought I would pose the question to those of you who know these things.
Does our ride need/have an oil sump? Is this something anyone has messed with?
5hairpins is offline   Reply With Quote
Old 03-14-2013, 02:16 PM   #2
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Perhaps someone more knowledgeable could chime in to help, but I think your discussion may have suggested dry sump applications.
See the following thread: http://www.ft86club.com/forums/showthread.php?t=7983
Anthonytpt is offline   Reply With Quote
Old 03-14-2013, 02:20 PM   #3
superpilun
Drives: 1986 MR2
An oil sump is just an oil pan. Your friends might have been referring to a dry sump. This basically replaces the oil pan with something much shallower and uses an external pump to manage the oil. You can read up on it here: http://www.drysump.com/drysump.htm
It's really only used on racecars. You'd see no benefit to this on a street car and the entire system will set you back several thousand dollars.
superpilun is offline   Reply With Quote
Old 03-14-2013, 02:50 PM   #4
turbo_jimbo
Drives: 01 MR-s, 78 280z, 13 FR-s
High end street cars use dry sump. It makes more power, and does a better job of lubricating. Only drawback is the price.
turbo_jimbo is offline   Reply With Quote
Old 03-14-2013, 06:49 PM   #5
GavinAnt
GavinAnt's Avatar
Drives: BRZ since 25 March, 2013
The real advantage of a dry sump is the oil is pumped and thus reaches places that might not get oil under high cornering speeds etc. only really relevant for track cars, not daily drives.
GavinAnt is offline   Reply With Quote
Old 03-14-2013, 07:41 PM   #6
5hairpins
5hairpins's Avatar
Much thanks for the replys, I will check out those links. My buddy who brought up the sump is a world class overdoer and would put in something like on a whim.
Old 03-17-2013, 08:54 AM   #7
Blue86
Drives: Sonic Blue 86GT Manual
I was impressed when I saw my brother's 1988 911 was dry sumped
Blue86 is offline   Reply With Quote
Old 03-18-2013, 07:57 PM   #8
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
As others have stated, generally if your car didn't come with a dry-sump from the factory (several cars do, one that comes to mind is the Z06) then you would likely only need it if you were racing your car or tracking it on a regular basis. I would argue that it is pretty important for a track car, but it is not inexpensive but does provide results.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 03-18-2013, 08:03 PM   #9
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
A dry sump with it's assocaited oil pump prevents parts of the motor from starving for oil under high g cornering manuvers. Like others have already said I doubt most street cars need this expensive option unless tracked heavily.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
