Old 01-05-2012, 02:43 PM   #1
[M]
[M]'s Avatar
Drives: Toyota Celica GTS
LED Conversion
Anyone been thinking about what lighting will come to the BRZ? I noticed here
[u2b]eP3SR1m_aRY[/U2b]
At 2:47 I noticed that the license plate lights were yellow, which got me thinking...are the dome,map,glovebox,trunk etc. lights going to be yellow( is it halogen?)
If so, I plan on doing a full LED conversion to either a 'cool' white or bright white. Does anyone else have a preference on this or is it just me!?
[M - Subaru BRZ]
[M] is offline   Reply With Quote
Old 01-05-2012, 03:42 PM   #2
Levi
Drives: Toyota
Yes, I always make a full LED cnversion in "cool white". The LED pack without errors costs about 40 €. That is not a problem. A bigger problem is LED blinker conversion.
Levi is offline   Reply With Quote
Old 01-05-2012, 03:47 PM   #3
Longhorn248
Hook 'em
Longhorn248's Avatar
The blinkers just require a little bit more than just the LEDs themselves.
Longhorn248 is offline   Reply With Quote
Old 01-05-2012, 04:02 PM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Only the non-HID headlights are halogen, everything else is a regular incandescent bulb.
No preference here, incandescent bulbs are fine with me. :shrug: I do prefer LED taillights though. And HID headlights.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-05-2012, 04:07 PM   #5
[M]
[M]'s Avatar
You know, I never have worked with doing blinker conversions. I had planned on doing it with my Integra but unfortunately didn't get around to doing it. I have had pretty good experiences with superbrightleds.com (US based) in the past. So I will most likely use them again.
Something about doing LEDs is just so appealing to me. I find that lighting, like wheels, can have a huge impact on the appearance on a vehicle. Which is why I was slightly disappointed seeing the lights in the video.
@Dave-ROR
As yes, thanks for clearing that up for me. I look forward to having factory HID headlights!
[M - Subaru BRZ]
Old 01-05-2012, 10:19 PM   #6
Slide
Drives: Toyota Aristo
@Dave-ROR
Can someone convert the fog lights to a cluster of LEDs?
Slide is offline   Reply With Quote
Old 01-05-2012, 10:24 PM   #7
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
I probably will, I like the cool white color. Everytime I get in someone else's car with stock incandescent bulbs I feel like the lighting sucks; its like its missing a certain sharpness to the overall aura of the car. I also have retrofited HID projectors in my car and they are amazing. Makes stock halogens look like crap, which means I will probably get some HIDs in the car to if they don't come stock.
^VLEDs sells some LEDs that go in the fog light housings
00NissanNinja is offline   Reply With Quote
Old 01-05-2012, 10:28 PM   #8
Slide
Thanks will look into it.
Old 01-05-2012, 10:30 PM   #9
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I've toyed with the idea of making some badass driving lights with 8 or so
old greg is offline   Reply With Quote
Old 01-06-2012, 12:12 AM   #10
Slide
Fuck yeah!!!
Old 01-06-2012, 12:22 AM   #11
Slide
lol...
Found some, need to find out the diamater of the fog light housing!
http://cutter.com.au/products.php?cat=Cree+XM-L
http://www.cutter.com.au/categories....+on+32mm+MCPCB
Old 01-06-2012, 12:34 AM   #12
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Just bear in mind, LEDs need to be run cool. If they feel warm to the touch they're too hot and are on their way to burning out. XM-Ls are about as efficient leds can be these days, but they'll still create a significant amount of waste heat that you'll need to safely dispose of. That means you're going to need a heatsink at the very least, you can't just stick them in a fog light housing and call it done. Then there's the power supply to consider (12v will do a pretty good job of melting them).
Old 01-06-2012, 12:38 AM   #13
Slide
Yeah just started reading the heating figures for the lights...
Not sure about the power thought :S what can be used?
Old 01-06-2012, 12:58 AM   #14
00NissanNinja
The Thread Lurker
You shouldn't need a separate power supply, resistors can be added to lower the voltage down to the the forward voltage of the LED which is usually about 1.5V. I usually get LEDs from Vled since they wire the resistors and add heat sinks as needed in a nice plug and play package. When I wired an LED in my dimmer switch all I needed was to solder in the proper resistor in series with the LED. Heat sinks will likely be needed for groups of higher power LEDs
