Old 03-22-2013, 04:04 AM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
front bumper removal?
slightly worried about doing this without some input. any help would be appreciated.
ft86me is offline   Reply With Quote
Old 03-22-2013, 02:28 PM   #2
P5yk0t1c
Drives: 2014 FR-S
Yes, I would like to know this as well...
P5yk0t1c is offline   Reply With Quote
Old 03-22-2013, 04:14 PM   #3
motrsprt9150
Boss
Drives: asdf
It's not bad at all, just follow the instructions here: http://www.ft86club.com/forums/showthread.php?t=8788
motrsprt9150 is offline   Reply With Quote
Old 06-10-2013, 12:13 AM   #4
Sensisnow
Drives: 05 TSX & 13 BRZ
I just took off my bumper using the instructions linked above. My only advice is to ignore what he said about just using force to remove the sidemarkers. There are 3 clips (only 2 accessible) holding it in. It helps if you use a small flat-tipped screwdriver to depress the lower clip, while pulling on the bottom of the sidemarker. When that is free, you'll have to insert the screwdriver into one of the top holes to depress that clip as well, while pulling towards the top of the sidemarker.
I tried using brute force, but was afraid that I would break something. Using a screwdriver to press in these clips made things much easier.
Sensisnow is offline   Reply With Quote
Old 06-10-2013, 01:28 PM   #5
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Just did this over the weekend and the sidemarker was the only part that worried me at first. Once you get the trick, it's so easy. I only turned the wheels one direction and had plenty of room on each side. A stubby screwdriver helps with clearance.
Just insert the screwdriver through the round hole in the metal bracket and push the tip forward and to the outside. POP.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Is the FRS front grill removal? mit_peid DIY (Do-It-Yourself) Guides 23 02-27-2016 01:00 AM
I F'd up my front bumper :'( TOTO_86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 48 08-14-2013 04:09 PM
Rear Bumper "diffuser" Removal sw20kosh DIY (Do-It-Yourself) Guides 6 07-31-2013 04:24 PM
WTB: Front BRZ WRB Bumper scraejtp Exterior Parts (Aero, Lighting, Etc.) 2 12-23-2012 09:56 PM
Front Bumper Lip ExWhyZer0 Cosmetic Modification (Interior/Exterior/Lighting) 5 10-22-2012 01:29 AM
