Drives: 2013 Ultramarine FRS
Slip+CEL = Bank1 running lean?
Today while out driving around, not crazy, just normal puttering around driving, my CEL and Slip light came on. The car ran fine but i pulled over and opened up torque asap. The code said that bank 1 was running lean. I turned the car off, let it sit a few minutes then turned it back on, lights still on, and car seems fine. I cleared the code and continued on my way figuring if it came back on, i'd start to get worried. 20 minutes of driving later, we are back home with the lights still off.
The car is stock other then a K&N CAI(installed last week), has ~3500 miles and is a MT. Should i be worried? Obviously if it happens again, i'm calling my dealership ASAP, but could it have just been a hickup? What are your thoughts kids? |
Drives: Moped
I'm betting money that the intake is making the car run lean (that's how many intakes make power...leaning out the fuel mixture)...if it's not properly calibrated, it may cause issues. I would consider a tune or taking off the K&N intake...
#3 | |
Drives: BRZ DGM Limited
Shouldn't the MAF adjust for the increased air flow to prevent a lean condition? |
That's what I was thinking too, it should adjust itself. Plus there is no way I'm maxing out the injectors with just intake. If it happens again ill put the oem intake back on and call the dealership.
Drives: 10 series FRS
What was the code? P...?
#6 | |
Drives: 2013 Subaru BRZ
Edit: In fact, the ECM is adjusting itself. That's why you're getting the lean code, as the fuel trim has strayed too far from the normal range, most likely due to the MAF change. |
Drives: Toyota GT86
same thing happened to me at the 3500km mark. My car has an injen intake and been running it for the past 2500km with no issues at all. I haven't checked the code tho, just unplugged the battery and reset the ecu.
Same issue happened to my friend's bone stock car!
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr) |
#8 | |
VMFIC ORLANDO SCIKOTICS
I had the same thing happen and the dealership said that it had to do with the fuel pump and the crickets sound. They ordered me one of the new fuel pumps but the are back ordered. My lights went back out after a couple days.
"Silence is acceptance so start talking or quit bitching!"
#10 |
Drives: Toyota GT86
Took it to dealer and the code read "bank 1 running lean". They updated the software with a new version and it's running fine since then, touch wood :p
#11 |
Drives: 86
Had this very same problem today, scheduled an appointment with the dealer for tomorrow :/ . My car is stock and has about 4000 miles.
#12 |
Red wine
Drives: Subaru BRZ(R.I.P)
I had this problem today, my issue was my MAF connector came loose, so I had to reconnect it. Slip light turned off, I cleared the code and everything was back to normal.
| CEL and Slip Light | Gums | AUSTRALIA | 10 | 01-15-2013 09:42 PM |
| CEL/SLIP repair impressions | Tricky1980 | Issues | Warranty | Recalls / TSB | 17 | 10-18-2012 07:52 PM |
| CEL and slip light? | Rob_g | Issues | Warranty | Recalls / TSB | 2 | 10-03-2012 05:57 PM |
| Scion FR-S, Limited slip dif (LSD)? | Dbringer | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 06-13-2012 04:02 AM |
| Torsen limited slip | BMWDavid | BRZ First-Gen (2012+) — General Topics | 41 | 06-12-2012 10:04 PM |
