Old 04-04-2013, 10:59 AM   #1
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Trick to restrat on last map used on ecutek
I'm frenchman with Toyota gt86 and FA20Club remap for 93 and E85.
I have found by my mistake when to much on a hurry that I can restart the car on the same Map as it was when I stopped it. I don't know if it only work for my car or will also work for other GT86/FRS/BRZ with ecutek.
So in France the GT86 is delivered with the smart key and the Push start button.
So my normal procedure to start with Map 3 that is my E85 map is like follow:
-1 press push start button 2 time (no clutch) to get all light on dash
-2 choose map with cruize control switch, Map 3 for E85
-3 Clutch down press again push start button and the car start in desired map.
So many time when on hurry i get confuse press too many time this button and suddenly start on the last map I was using. But I could not reproduce it when I wanted it.
So today I decided investigat and to test more to be able to reproduce my mistake and after a bit of trial I could reproduce it a few time's.
So here is how it work for my car to restart in the last map before it was stoped:
-1 Press 3 time very fast the push start button
-2 Clutch down and press Push start botton, the car start
-3 pull cruize control to check what map is on and Bingo Map 3 same as when I stop it.
I try to leave the car 4 hour to check if this still work and again Map 3 at start.
Would be intresting to know if other's can reproduce this?
I will try if it work in the morning after staying all night in garage
Mars2 is offline   Reply With Quote
Old 04-04-2013, 11:05 AM   #2
Foobar
SLO NO MO
Foobar's Avatar
I'll try it right now and report back.
So basically, always start with 3 quick pushes of start, then clutch-in start?
Old 04-04-2013, 11:06 AM   #3
Mars2
Yes it's how it work on my car
Old 04-04-2013, 11:12 AM   #4
Foobar
SLO NO MO
Foobar's Avatar
Son of a bitch... Confirmed working on my car.
Why would this work this way?
Sent from my Nexus 4 using Tapatalk 2
Old 04-04-2013, 11:16 AM   #5
Mars2
YES I'm happy I'm not the only one.
Some time mistake's make you do great discovery
Old 04-04-2013, 11:20 AM   #6
xxscaxx
Drives: 2013 SWP BRZ
pushing the button 3 times would bring it back to its off position. so you have to basically turn it on quickly to shut it off, then clutch in and start it with one push?
I will check this out later today when I leave work to confirm if it works on my car
xxscaxx is offline   Reply With Quote
Old 04-04-2013, 11:28 AM   #7
Foobar
SLO NO MO
Foobar's Avatar
Exactly
Old 04-04-2013, 11:38 AM   #8
xwd
I noticed one time mine was in the old map position but had no idea how, this must have been it.
Old 04-04-2013, 11:44 AM   #9
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
hmmmm, now to try this with out a push start.......
Bu-Tang is offline   Reply With Quote
Old 04-04-2013, 11:55 AM   #10
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
This works on non push button starts as well. I have seen this happen on my auto frs when forgetting to put it back on the e85 map.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 04-04-2013, 11:55 AM   #11
Mars2
No exactly 3 push put it back where you have one green key light on dash.
With 2 push you 2 green key light on dash.
Old 04-04-2013, 12:10 PM   #12
Foobar
SLO NO MO
Foobar's Avatar
3 returns mine to off, but when I start up with the 4th push, it retains the previous map.
Old 04-04-2013, 12:33 PM   #13
xxscaxx
I thought the e85 map was a separate map anyways from a regular pump map? I know features are probably structured the same like on a pump map (flat foot shifting, auto blip, etc).
Its funny how I never use any of the features on my pump map. Sometimes I use the auto blip which is cool, but lately have been practicing heel-toe so much to get it right myself anyways that I rather not use it. I could always blip for downshifting but not in the proper way so i've been trying to perfect it.
Old 04-04-2013, 12:35 PM   #14
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Maybe visconti can have some input as to why this happens? @Visconti
Lee358 is offline   Reply With Quote
Airbag light trick for racing seats. Ricepuddin DIY (Do-It-Yourself) Guides 111 03-18-2024 09:05 AM
I need help on which ecutek I should get, stg 1 or 2 Frsexxxy Engine, Exhaust, Transmission 22 03-29-2013 11:45 PM
Which should I get ecutek stg 1 or stg 2? Frsexxxy Engine, Exhaust, Transmission 5 03-21-2013 02:10 PM
Delivery fee dealership trick oldpueblo Scion FR-S / Toyota 86 GT86 General Forum 6 10-18-2012 10:29 PM
