Old 04-04-2013, 07:43 PM   #1
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
About the 16" wheels some countries get as standard
Unlike the US and other countries, in Peru the starter version of the GT86s has 16" tires. There's a better version but it's $8k more and I'm not paying $8k more to get the 17" rims/tires, bigger brakes and small comforts like keyless entry, etc.
This version has the following tire/rim combo: 205 / 55 R16 6.5J
and most online reviews are made with the 17" combo other countries get 215 / 45 R17 7J
I've done my fair share of reading on tires/suspension and I keep wondering if these 16" rims/tires will give me a diluted experience on the car. I'm told that the suspension is the same, but what changes is just the rim and rubber. Has anyone driven both versions to give an opinion?
On the note of upgrading tires/rims, I'm still confused on what to do. I don't want to lower the car because we get lots of speedbumps, and I don't want to ruin the car's character. I've seen other users setups with awesome 18x8 front and 18x9 in the back, but I keep wondering if the larger rear wheels would produce understeer because of the larger amount of rubber on the road..
OnionTou is offline   Reply With Quote
Old 04-04-2013, 08:46 PM   #2
CSG David
CSG David's Avatar
The 16" wheel will give you a much more comfy ride. It is slightly detuned in a way to make the car more affordable and more comfortable for the every day user. Toyota also knows that it's a tuner's car. Keep tires and wheels square. Changing the width sizes will change the characteristics of the car. What kind of goals do you have for the car?
Old 04-04-2013, 08:53 PM   #3
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
Yes, if you put wider rubber in the rear, you'll induce understeer because you're giving the rears more grip (and thus, the fronts have less). Stick with a square wheel setup (same size wheels all around) to keep the car's character
hushypushy is offline   Reply With Quote
Old 04-04-2013, 09:02 PM   #4
tisb0b
Drives: Grey GT86 MT
I went from a 205/55 R16 to 225/40 R18 18x7.5" +48 rim and I didn't notice much of a difference in ride quality.
tisb0b is offline   Reply With Quote
Old 04-05-2013, 01:04 AM   #5
Turdinator
Señor Member
Turdinator's Avatar
I believe the lower spec car (the GT here in Aus) is lighter and is the model spec they used for the suspension development so i doubt it will be any worse than the cars with 17" wheels. And i know its not the ultimate comparison but during spirited driving on cruises i certainly havent had trouble keeping up with the up spec model.
1974 TA22 Celica
2013 86 GT
Old 04-05-2013, 03:00 AM   #6
59186
Drives: Gt86
It is also true for Chinese spec 86! I am also worrying higher profile tires will seriously affect the performance!
59186 is offline   Reply With Quote
Old 04-05-2013, 08:00 AM   #7
AbsolutKev86
AbsolutKev86's Avatar
Drives: Toyota 86 & Ford Expedition EL
Tada San wants the car to b a fun car. The rear is made to slide out easily but if u go for huge rims with thick tyres it ll b changing the whole characteristic of the car. Its really up to the owner.
Btw in UAE we get the 16s too. They are made by Enkei n weight ok.. So im in a dilemma either to go for a lighter 16" like the 16x7 sbc rpf1 with a 215/55/16 or 225/50/16
Or
17X7 with 215/45/17.
AbsolutKev86 is offline   Reply With Quote
Old 04-05-2013, 09:38 AM   #8
AbsolutKev86
Old 04-05-2013, 09:42 AM   #9
CBR600RR
Drives: Raven Black
I ride on 16s in the winter here in canada and I can assure you they don't dilute the driving experience. the handelling feels the same to me. the ride over bumps is only slightly softer.
Old 04-05-2013, 09:51 AM   #10
Blue86
Drives: Sonic Blue 86GT Manual
The tyres on my stock 16" rims were downright shitful! So happy I changed wheels and tyres
Blue86 is offline   Reply With Quote
Old 04-05-2013, 10:57 AM   #11
OnionTou
OnionTou's Avatar
Thanks for the tip. It'll be my 2nd mod (and it's not exactly a cheap mod, so I gotta wait it out a bit). First mod will be a decent radio!
Old 06-12-2013, 10:13 AM   #12
Trettiosjuan
Drives: GT86
You could just get some "extreme summer performance tyres" with a stiff sidewall, e.g RE-11, AD08, Starspecs, etc. which will give you a significantly better response and dry grip (but worse aquaplaning properties). But really, all the vids I saw with the stock 16", handling looked just fine.
Trettiosjuan is offline   Reply With Quote
Rays Volk-Racing TE37SL 18" & Yokohama Advan RS-II 18" wheels eauto Wheels and Tires 3 01-10-2013 06:50 AM
TSW Wheels 17" 18" Nurburing + Interlagos and More (Wheel+Tire Package Available) MIKE@MRTIRESOLUTIONS Wheels and Tires 0 12-20-2012 06:12 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
>>> MOTEGI WHEELS 17"/18" - INCLUDING MR121/MR125 ROTARY FORGED @ 17 LBS/19 LBS BestWheelDeals Wheels and Tires 2 09-07-2012 10:26 PM
