| DIY (Do-It-Yourself) Guides For all DIYs. |
#1 | ||||||
give us this day
Drives: AE86 - FRS
DIY - Simplified Frs Fog Lights
Heres everything you need to know how to install a fog light on your frs..
Here's all the references I used.. FRS Fogs using BRZ Stalk http://www.ft86club.com/forums/showthread.php?t=29263 Fog Light Powered with Factory Stalk and BCM http://www.ft86club.com/forums/showthread.php?t=33025 Scion Frs Fog Lights http://www.ft86club.com/forums/showthread.php?t=27581 for more information and guide please visit these threads above.. ![]() Parts Needed: 1. L&R Fog Lights $84 Quote:
Item#: 83115FJ070 http://subarupartsforyou.com/cp_part...p?partid=23294 H11 Harness $7 Any h11 harness you prefer, wether you buy one from amazon.com [ame="http://www.amazon.com/Headlight-Connector-Socket-Harness-Moisture/dp/B002MVNM8W/ref=sr_1_9?ie=UTF8&qid=1369066530&sr=8-9&keywords=h11+harness"]http://www.amazon.com/Headlight-Connector-Socket-Harness-Moisture/dp/B002MVNM8W/ref=sr_1_9?ie=UTF8&qid=1369066530&sr=8-9&keywords=h11+harness[/ame] Mounting Hardwares $5 You need 4x m5 or m6 Allen bolts, 4x m5 or m6 washer, 4x nylon m5 or m6 nuts. Extra Harness Pins, to make a new harness with your h11 connectors, to connect to the signal lights connectors. ![]() http://www.ft86club.com/forums/showt...=29263&page=12 Or get the full kit at Ishii Motors http://www.ft86club.com/forums/showthread.php?t=34078 for $385 2. Start by disconnecting the battery 3. Positive Terminal disconnected 4. 3x fuses for the Horn were taken off. Heres a reference http://www.ft86club.com/forums/showthread.php?t=12257 5. Now take off plastic splash guard underneath the bumper, both passenger and driver sides, there 1x 10mm nut you need to take off and 2 pop offs on each side.. 6. take off the plastic cover on passenger side, be patient, you can actually pull it off once you get a corner off. ![]() 7. Now same for the driver side just carefully take off driver side plastic cover 8. Here both driver and passenger side plastic covers are taken off 9. Now its time to take the steering wheel off, first you need to take the airbag off. once again dont forget to disconnect battery off. now go to the cabin and push the pin forward the center of the steering wheel on all three holes. while pulling the airbag itself towards you. Reference http://www.ft86club.com/forums/showt...ghlight=Airbag 10. remove the orange, black harness and ground for the horn off the airbag. remove the nut that's holding the steering wheel, then gently pull the steering wheel towards you. 11. make sure to tape the steering angle sensor so it does not move I used a tape to make sure it does not move, basically you want the orange to be visible in the window just like the picture. 12. remove two bolts to take upper and lower plastic steering cover. Quote:
![]() 13. now remove the white connector on the steering angle sensor 14. remove all off the sensors underneath, the yellow one is a tricky one you actually need to push it from the end. Quote:
16. Then unclip the clip on the 9 oclock position to remove the steering angle sensor 17. Finally, unclip the clip on the 3 oclock position to remove the steering anlge sensor 19. You need to remove the wiper switch first before you take the light switch stalk. ![]() 18. After removing the sensor, locate the clamp thats holding the switch, the clamp is at the back at your 12 oclock, just squeeze the clamp thats holding the original stalk switch at the back and wiggle the stalk out towards you.. It might take some time but be patient and wiggle it in and out towards you. The idea is to push it away first to get it off the notch that's holding it then quickly pulling it towards you. 20. you should see this when you take the original stalk switch while depressing the clamp and pulling it towards you. Quote:
22-23. take off the original turn signal lights driver and passenger side harness, and make a new one by putting a new pin on the fourth slot. and tappping into the black wire for ground. Refer to.. Quote:
24-25. install fog lights. your choice of hardwares. Just so you know the top is larger than the bottom. So you might wanna buy two different sizes of bolts. Also an Allen stylel bolts works best for me. ![]() 26. you should now end up with this ![]() 27. turn fog light switch on 28-29. enjoy! 30. Also ere is a fog light indicator inside the cabin! For more higher resolution pictures please click the link below: http://s1353.photobucket.com/user/im...%20Light%20FRS If youre having s hard time following you need to read the first three references for you to fully understand what is going on.. Please take the time to do some research... as I did as well.. But I hope these pictures will guide you.. If you have any questions feel free to send me a message!! Have a good one! To the op's , if you guys have any suggestion on the write up I can make some changes. As I was rushing typing this down..
Excellent job combining everything we have all found and making an easy to follow DIY.
Drives: Raven Black
OR... you could just get switchback blinkers, and BOOM!!!! - fog lights
Toyota Freak
Drives: Whiteout FRS
i like ur price better, than 385.
![]() ![]() ![]() this fog lites, what is their rating?
![]() Last edited by njccmd2002; 04-20-2013 at 12:25 AM. |
Toyota Freak
sorry to post again, but i read on another post "that the auto on brz stalk" does not work, what is that, i just went through 21 pages and did not find out what they are talking about.
#6 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
"Auto" on the BRZ stalk is a feature that requires an ambient light sensor to sense when (daytime/nighttime) to "automatically" turn on or off the headlights without manually doing it (when set to "Auto" mode). Unfortunately the FR-S does not have this feature so if you use the BRZ stalk for the foglights, the extra "Auto" feature will be useless.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
give us this day
Drives: AE86 - FRS
im sure in no time we'll find a way how to do it.. and when that time comes .. i already have the brz stalk switch with auto function
#8 | |
Toyota Freak
oh thanks, but there might be a way!!!! wonder if we can retro fit a conlight unit from toyota...
give us this day
Drives: AE86 - FRS
already working on it as we speak
haha
#10 |
Drives: Awesome
are you using the the unit from the brz?
#11 |
give us this day
Drives: AE86 - FRS
ya.. buying the sensor from subaru.. still looking for the barnes.. looks like its there..
#12 |
Drives: Awesome
okay. cant wait to see the results. by the looks of it there is s need to puncture the area on the dash.
#13 | |
give us this day
Drives: AE86 - FRS
#14 |
Drives: 2015 Tacoma
Just ordered my kit and harness through Nigel getting ready to install this week but had two questions:
1. Is there an oem mounting solution with part #'s listed? (Sorry if I missed that) 2. With the brz stalk is it only possible to run the fogs when the low beams are enabled? |
| **PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) | PhastekSport | Exterior Parts - Lighting | 18 | 07-09-2014 08:42 PM |
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 09:38 PM |
| FR-S Fog lights | ggpaul | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 11-25-2012 12:28 AM |
| FRS HID lights? | easybreazy | Cosmetic Modification (Interior/Exterior/Lighting) | 84 | 08-27-2012 11:21 PM |
| Fog lights on with parking/running lights possible? | BMWDavid | BRZ First-Gen (2012+) — General Topics | 1 | 06-16-2012 08:29 PM |
