Old 04-22-2013, 04:29 AM   #1
amaroocars
Drives: Toyota 86
Aftermarket GPS Head Unit for Aussies
The original for Aussie 86 GTS are made by Fujitsu TEN under the name of Eclipse. I used to be involved with bringing in units from Japan/China and Korean and most of the units now are all fully built or components made in China. Even some of the top brands are just final testing or facia fitted in Japan.
I am retired electronics guy and getting a 86 gts in June but a mate who bought a std 86 wanted a good GPS that was a good match for GTS. I arranged to get 2 units from manufacturer and I installed one 2 weeks ago. Works and looks great.
I have still got one but he says someone wants it after seeing his. If anyone in West Aussie is keen to look or purchase one I can get more direct from manufacturer, would be about $390 inc maps for Aussie and lots of features. If your interested and in WA then I can send you full details or better still, you drop around and check it out.
Can also to install it for a small fee, advice is free.
Get back to me for info
amaroocars is offline   Reply With Quote
Old 04-30-2013, 10:16 AM   #2
Blunt
Drives: WRB BRZ MT
I'm about to order a BRZ so the head unit will definitely need replacement. Are these units Fujitsu/Eclipse or something else? Does the unit have Bluetooth calling or streaming? Do you need a fascia kit? (Will be getting the optional faux carbon dash from the GTS). Any pics? Cheers.
Blunt is offline   Reply With Quote
OEM mic with aftermarket head unit phenom86 Electronics | Audio | NAV | Infotainment 13 05-10-2013 12:20 AM
BRZ Stock Head Unit + Aftermarket Amp + 3-way Components question daforce007 Electronics | Audio | NAV | Infotainment 13 04-14-2013 05:42 PM
Which harnesses for aftermarket head unit in BRZ? xjohnx Electronics | Audio | NAV | Infotainment 6 02-26-2013 09:24 AM
FRS aftermarket head unit installation - wiring MindtheGap Electronics | Audio | NAV | Infotainment 35 01-14-2013 10:00 PM
Best aftermarket head unit mounting kit? TRBO2NR Electronics | Audio | NAV | Infotainment 1 10-13-2012 03:21 AM
