Old 04-22-2013, 06:14 PM   #1
Itssrayyxd
Drives: Scion frs.
Eibach sportline springs with stock shocks
Can I run the springs on stock shocks or will I have to get koni shocks?
Itssrayyxd is offline   Reply With Quote
Old 04-22-2013, 06:18 PM   #2
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
you can run on stock shocks no problems.
just a heads up you'll want to budget for some rear end camber correction with these springs.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 04-22-2013, 06:18 PM   #3
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I rode on Sportlines and stock struts/shocks for 4k miles... Rode nice, but I can't really speak for longevity as they're not being used anymore... however, they were still functioning normally...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-22-2013, 06:24 PM   #4
Itssrayyxd
Drives: Scion frs.
Can you elaborate? This is first car and I don't understand anything about the wheels and camber. Like when it's like 17x8.5 +35. I don't understand that lol.
Old 04-22-2013, 06:25 PM   #5
Itssrayyxd
Drives: Scion frs.
Also, I plan on running the springs with stock wheels as well
Old 04-23-2013, 03:58 AM   #6
Itssrayyxd
Drives: Scion frs.
Did you have any clearance problems? For like driveways, bumps, and dips?
Old 04-23-2013, 06:25 AM   #7
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Not really
Omar GC
Instagram: 2jzus
Old 04-23-2013, 02:56 PM   #8
CSG David
CSG David's Avatar
Our car is lower than Robispec's car right now. Clearance is still not much of an issue...
Old 04-24-2013, 01:23 PM   #9
f0rge
Yeah, because of the way the suspension is designed, when you lower the car there is an excessive amount of negative camber on the rear wheels. What that means is that the wheels are tilted in at the top beyond what the manufacturer specs recommend. You will need to get lower control arms or some other form of adjustment to bring the camber back closer to stock. Side effects of not doing this are possible increased tire wear and possible negative impacts on handling.
The specs on those wheels mean:
17 is the size in inches of the rim, diameter.
8.5 is the width in inches of the rim
+35 is the offset.
Old 08-25-2013, 07:49 PM   #10
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I just received my Sportline springs the other day. I too am also new to modifying suspension. I have not purchased anything besides wheel spacers and the Sportline springs.
What else do I need to invest in? Do I need front camber bolts? Or just rear?
Which do you recommend?
ericmpena is offline   Reply With Quote
Old 02-11-2014, 12:46 PM   #11
Verbal21
Verbal21's Avatar
Drives: 370Z
I'm in the same boat. Any recommendations?
Verbal21 is offline   Reply With Quote
Old 02-11-2014, 12:49 PM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I ran them for awhile without rear camber adjustment. Not ideal but... :shrug:
Personally I'd suggest adjustable UCAs like the RacerX setup.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2014, 01:37 PM   #13
ericmpena
ericmpena's Avatar
Do you already have the Sportlines?
Old 02-11-2014, 01:40 PM   #14
Verbal21
Verbal21's Avatar
Drives: 370Z
I was actually about to buy some later today once I get out of work.
I was also looking into Pro Kit's too but can't find info on whether they'd need a camber kit as well or not.
Eibach Sportline Springs Review Oh Damn Andrew Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-29-2019 03:26 PM
Eibach Sportline springs with 20mm front and 25mm rear spacers on stock wheels Calin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 12-12-2014 03:25 PM
WTB: Eibach Sportline Springs t00n3wb Brakes, Suspension, Chassis 2 05-01-2013 09:52 PM
FS: Eibach Sportline Springs crizkay Brakes, Suspension, Chassis 1 03-01-2013 11:52 PM
FS: Eibach Sportline Springs in AZ AZ BRZ Brakes, Suspension, Chassis 14 02-05-2013 08:27 PM
