Old 04-23-2013, 11:23 AM   #1
Xdragonxb0i
Drives: ex500r
P&L Catted headers and Nameless catted Front pipe. *FIXED*
I thought i share a video of my set up with you guys. P&L Catted headers and Nameless catted Front pipe w/ resonator. Thank you guys fore the help. I only was able to make one video today, but i think it is a very good set up for DD, quiet under 4000rpm while cruising, and realy screams WOT and High revs.
@shu5892001 you can delete the old videos, I would also appreciate it if you told me how to post embed videos.
[ame]http://youtu.be/sX1Ec8CMJUA[/ame]
Xdragonxb0i is offline   Reply With Quote
Old 04-23-2013, 11:50 AM   #2
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
[ame="http://youtu.be/RVar0NoDbEM"][/ame].
shu5892001 is offline   Reply With Quote
Old 04-23-2013, 11:55 AM   #3
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
Sounds like the dry clutch on my Ducati.
Did you check for leaks on all of the flanges? Headers typically are thinner metal so you will hear some new sounds. Ill let someone chime in on this though.
fender9530 is offline   Reply With Quote
Old 04-23-2013, 12:02 PM   #4
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Yup, sounds like a leak at one of your flanges. Did you over-torque the bolts?
Scott
naikaidriver is offline   Reply With Quote
Old 04-23-2013, 12:17 PM   #5
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Mine didn't sound like that. It's most likely an exhast leak like they said.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 04-23-2013, 12:24 PM   #6
djdnz
1337
Drives: 2013 BRZ WRB S/C
Exhaust leak, make sure you loosely tighten all your bolts before torquing them. Did you install any new gaskets? If you drive like this for long enough, eventually when you take it apart you will find out where it was leaking from, there will be exhaust soot making its way out of one of the flanges.
Video two almost would lead me to believe you have a bit of vibration/resonance as well. Fix the exhaust leak first and then if it doesn't go away see if there is some heat shielding rubbing. Could just be a raspy header/exhaust combo though...
djdnz is offline   Reply With Quote
Old 04-23-2013, 12:48 PM   #7
Xdragonxb0i
Drives: ex500r
i used the old gaskets, but okay thanx for the inputs. I will tighten all the bolts, and look for any leaks.
Old 04-23-2013, 12:51 PM   #8
swift996
swift996's Avatar
Similar situation (I'm running the FA20Club headers). I can't see your vids at work but I had an exhaust leak. Replaced the gaskets today and it's much better, still sounds like there might be a small leak at the V-band.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 04-23-2013, 04:10 PM   #9
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
sounds like and exhaust leak, hope you find and fix it!
Deepseadiver is offline   Reply With Quote
Old 04-23-2013, 04:34 PM   #10
naikaidriver
Don't just tighten the bolts unless they need it!
If you didn't use a torque wrench when you installed the header, you could have over-torqued the bolts, which could warp the flanges. You could also end up shearing off one of your flange bolts and with an aluminum head... this is BAD!
Before you tighten anything, look around both your flanges and your collector for black, carbon scoring. This will point you where your leak is. Once you find the leak, replace that gasket with a new one, get a torque wrench and tighten it properly.
I'm not picking on you, just helping make sure you don't inadvertently make your problems bigger!
Scott
Old 04-23-2013, 04:48 PM   #11
P&L Motorsports
P&L Motorsports's Avatar
Drives: '13 Turbo BRZ (AT) & '13 FRS
Give us a call if you think we can help at all, otherwise the community here has pointed you in the right direction.
-Dylan@P&L
P&L Motorsports is offline   Reply With Quote
Old 04-23-2013, 05:39 PM   #12
mad_sb
Drives: 2013 Asphalt FR-S
@Xdragonxb0i You have an exhaust leak my friend.... and i fail at read before post lol.
Originally Posted by shu5892001 View Post
Old 04-23-2013, 05:45 PM   #13
shu5892001
Ontario's FT86
not my car... I only helped to post youtube videos.
Old 04-23-2013, 05:58 PM   #14
youcantseeme24
youcantseeme24's Avatar
Drives: 2013 subaru brz
new gasket torque evenly and you should be good to go
youcantseeme24 is offline   Reply With Quote
Perrin or Invidia Catted Front Pipe? husker741 Engine, Exhaust, Transmission 30 08-24-2017 01:26 PM
Perrin or Berk catted front pipe JDKane527 Engine, Exhaust, Transmission 22 08-12-2017 03:01 PM
Catted Headers EN2_Squirrel Engine, Exhaust, Transmission 53 12-16-2016 10:52 PM
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
Motiv Concepts Overpipe and catted front pipe NIB ABQautoxer Engine, Exhaust, Bolt-Ons 8 12-11-2012 01:21 PM
