Old 01-26-2012, 09:18 AM   #1
maxeveland
maxeveland's Avatar
Drives: n/a
Can you manually shift automatic version w/out the paddle shifters?
I notice in the interior images the automatic frs has the look of the manual and the frs is described as having paddle shifters but do you have the option of moving the stick shift up and down?
And does anyone know if the BRZ will have the same looking automatic?
maxeveland is offline   Reply With Quote
Old 01-26-2012, 09:30 AM   #2
Argent6978
Argent6978's Avatar
Drives: '05 Focus ZX3, soon '13 Scion FR-S
One would assume you could move the stick shift up and down, else it would be very very difficult to get it out of Park.
Looking at the interior images on Scion's page, the shift lever does seem to indicate that when in Drive, it can be pulled a little to the left and used to shift up and down as well.
Argent6978 is offline   Reply With Quote
Old 01-26-2012, 11:37 AM   #3
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Originally Posted by LSxJunkie View Post
Yes, but Toyota still insists on using the wrong layout. It should be pull aft to shift up and push forward to shift down. This way the motion of your hand works with the g-force of the car accelerating and braking.
I only use the paddles in the IS350 because that annoys me to no end.
The same way GM fucked up their paddles on the Corvette. You pull right to shift up, pull left to shift down. You don't push either paddle forward to shift up and pull to shift down. That's retarded. Thankfully they got it right on the CTS-V.
Man the corvette is like this? WOW that is crappy crazy yo! Hopefully they fix it in the next corvette in 2014..
tripjammer is offline   Reply With Quote
Old 01-26-2012, 12:18 PM   #4
Dragonitti
Saw the title and thought...."Why on earth would you want to do that?"
Old 01-26-2012, 12:31 PM   #5
madfast
Drives: 2010 Evo X MR-T
both porsche and BMW did this until very recently. in fact i think the cayman s still uses that old tiptronic style of "paddles".
madfast is offline   Reply With Quote
Old 01-27-2012, 12:23 PM   #6
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
This always annoys me to no end. Every time I drive a rental or loaner car that has it backwards (ie, anyone but Mazda and BMW), I have to think about EVERY shift to make sure I go the right (wrong) way.
PULL BACK FOR UP.
PUSH FORWARD FOR DOWN.
Every racecar with a sequential gearbox is like this. If there are paddles, right paddle for UP, left paddle for Down. The only thing worse than getting it opposite is Chrysler's shifter that's side-to-side.
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 01-27-2012, 12:33 PM   #7
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Bmw got it right. I remember driving an e43 m3 smg and it was the right layout. Very crisp and positive feedback too. A lot of automatic cars with paddles have this short lag after chnaging gears.
TylerLieberman is offline   Reply With Quote
Old 01-27-2012, 02:37 PM   #8
madfast
pull back for upshift, companies that get it right: BMW, mazda, suzuki, fiat, and mitsu's SST.
worst offender of push forward upshift: VAG. cars like the R8 and veyron and all PDK porsches could have used whatever style they wanted, and yet they still kept the push forward upshift. what a shame. AND some VAG cars make you push the shifter to the right in order to access the push/pull console shift action. for a left hand drive car, this is away from the driver, wtf?
Old 01-27-2012, 03:22 PM   #9
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I like push down for downshift and up for upshift. Why? It makes sense to me. The opposite way is confusing.
SUB-FT86 is offline   Reply With Quote
Old 01-27-2012, 06:51 PM   #10
madfast
but do you like it only because you're used to it?
the way they usually do it, in racing, is pull back for upshift. many theories on why but i think we can all agree that in racing that's the way they do it. so why does almost everybody do it pull back for downshift? IMO it has to do with the PRNDL/PRND321 convention. in that convention pull back is downshift, so its all about familiarity. car manufacturers probably value familiarity and convention over doing it the "racecar-way". and that's why "sporty" car companies like BMW and mazda choose to do it the "right" way. they have enough balls to defy convention and do whats best for the driving experience.
the same can be said with the paddles. it went from pushing buttons (very familiar to have buttons on the steering wheel, so why not to change gears right?), to toggle "paddles" (half way between buttons and actual paddles), to the ones we have today (no doubt F1 and ferrari's use in it's cars have made these the standard when it comes to steering wheel mounted gear selection).
Old 01-28-2012, 01:14 PM   #11
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I've driven an IS-F with the same trans tune as this car is purported to have (except that's an 8 speed) around Monticello. The torque converter essentially acts like a clutch. Once you're rolled away from a stop, the converter is locked, except when you downshift. The converter unlocks so the engine can rev-match. That car shifted pretty much instantly. I still wish it had a stick, but with a torque converter automatic, that really is the best experience I could ask for. I actually prefer it to SMG II because the torque converter reacts normally at low speeds, so you don't hammer a clutch trying to drive sedately or parallel parking.
I used to have a M3 with SMG II and I've driven my buddy's IS-F around a short improvised track/course. Like you said the tranny in the IS-F is really nice. I'd say 99% as good as the SMG was on the M3. Shifts seemed just as fast and felt way~ smoother on the road. One thing that it "felt" a tiny bit behind the SMG was on downshifts, especially if they were multiple gears, but I'm completely splitting hairs.
If I had to choose between the two, I'd choose the one in the IS-F because it's easier to live with on a DD. If had to pick the best "auto" tranny I've ever had the pleasure of driving is the one in the E63 AMG. It's basically a torque converter less tranny so something close to a SMG, but much better in execution. Best of both worlds!
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 01-28-2012, 02:40 PM   #12
FRSpdDmn
I've driven an IS-F, too. The Auto works well for what it is. They're not the only one, though. Every current BMW locks up the torque converter after launching in 1st gear and also rev-matches it's downshifts.
If you truly want the best of both worlds, the double-clutch gearboxes is where it's at. Instantaneous shifts with none of the clunkiness of the old SMG's and none of the power loss of a torque converter. I'm talking about Audi/VW's DSG, BMW's DCT, and Porsche's PDK, among others. I still love the connection through the manual gearbox and won't give that up for a pleasure car. If I were looking to gain those hundredths of a second in racing, it's hard to argue with the automated manuals. And they never miss a shift.
-Anthony
Old 01-28-2012, 04:37 PM   #13
madfast
what makes the IS-F's 8 speed special is the solenoids. that's how they achieve such quick shifts. at the time, it was touted as the fastest shifting production tranny. early TC lock should be on every AT. it makes the driving feel better and gets better mpg. its win-win. so yeah TC lock up and rev matching isnt new, but the IS-F solenoids are. once we see more of this tech, they will achieve parity with DCTs very quickly.
i disagree. the IS-F shows that you can have super quick shifts in a TC AT. as quick as DCT or AMT? no, but lets be honest here, you're splitting hairs if you want to talk about milliseconds. the cost and complexity of the DSG is it's downfall. firstly, low speed operation will never be as smooth as an AT. secondly, you're at the mercy of its computers way more than an AT. with the computer controlling the clutch, you never have full control. you're at the mercy of however it was programmed. with an AT you will at least have a viscous connection through the TC at all times. and lastly, the tranny is non-serviceable. out of warranty and the DCT dies? guess what? you're SOL...
the absolute best of both worlds is the Mazda SkyActiv AT. it uses a very small TC that locks up super early. you can think of it as a clutch slipping device, because basically that's all they're using it for. right now its on an economy car, but the principle of operation can be expanded to a sporty AT very easily. for example, combine the small TC, early lockup philosophy with the solenoids of the IS-F, and you'll get one awesome conventional AT.
Old 01-29-2012, 02:45 AM   #14
Godzpeed
Drives: Nissan GTR
BMW has always used pull down to shift up and push up to shift down like a sequential gear box on the gear lever
M cars had proper paddle shift (right to shift up and left to shift down). regular Steptronic had pull to shift up and push to shift down until recently.
and thats not the Tiptronic style paddles, Tiptronic uses buttons on the steering wheel. Those are the regular PDK shifter. you need to order the optional sport steering for proper paddle shift. the regular PDK wheel is still standard on every Porsche including the newest 991
Godzpeed is offline   Reply With Quote
Toyota's Automatic sequential shift davey90 Engine, Exhaust, Transmission 11 12-23-2011 01:18 AM
Paddle-Shifters Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 45 09-14-2011 01:20 AM
6MT vs Paddle shiftting Auto Dragonitti Scion FR-S / Toyota 86 GT86 General Forum 149 07-03-2011 01:20 AM
Need For Speed Shift 2 Dragonitti Other Vehicles & General Automotive Discussions 12 04-09-2011 11:49 PM
Shift Apparel Lexicon101 Other Vehicles & General Automotive Discussions 2 05-02-2010 01:44 AM
