Old 04-23-2013, 10:55 PM   #1
keen as
keen as's Avatar
Drives: 86 GT MT
Wheel offset change handling?
I am considering 17x 8" rim width on 235 rubber.
Both 45 and 35 offset will fit. The 45 will keep the wheel centred on the hub, the 35 will make the wheel flush.
At a high performance level, has anyone noticed any handling changes at the 35 offset? Will the 35 offset be detrimental to the hub? ...thanks.
keen as is offline   Reply With Quote
Old 04-23-2013, 10:59 PM   #2
NickFRS
Drives: 2013 Asphalt FRS
All about driver mod
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 04-23-2013, 11:50 PM   #3
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Yes there is a noticeable difference with near a 1" wider track difference from stock on +35mm offset wheels. I have +36mm offset Kosei K4R's in 17x8 size with 215/45-17 Kumho Ecsta XS tires and its harder to sling the car around/kick out the rear, it's much more stable and also more responsive to wheel inputs. Very good stability and responsiveness on track. With a narrower track, all else being equal, it would be slightly less stable and less direct in handling.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Stock wheel offset vs +38 in the rear post_break FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 11-18-2012 12:15 AM
Stock Wheel offset smbrm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-15-2012 01:09 PM
wheel offset post pics! gt86init Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-06-2012 06:23 PM
deep dish wheel offset CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 02-19-2012 07:45 PM
Wheel offset on watanabes? Decameron Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2010 06:20 PM
