Old 04-27-2013, 09:54 PM   #1
Sonolin
Headers & downpipe/overpipe installation
So, I'm curious how hard is the nameless dp/op install? Can it be down with just jack & stands?
I've heard you have to lift the engine to install it. Is that true? I don't own an engine lift unfortunately.
How about headers? Do these require the engine to be lifted?
Thanks... 90% sure I want to go nameless op/dp combo, not sure on headers yet.
Sonolin is offline   Reply With Quote
Old 04-27-2013, 10:22 PM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I heard the over/front pipe is doable without a lift but is a squeeze, regarding the headers you won't need any type of lifting and I guess it's easier than the overpipe (I guess)
Old 04-27-2013, 11:30 PM   #3
Argento_FR-S
Drives: Scion FR-S
With my SRT header-back the hardest part was just getting the stock overpipe out. Takes a good bit of twisting and maneuvering, but isn't too bad. I managed to do the whole exhaust on jackstands.
Argento_FR-S is offline   Reply With Quote
Old 04-28-2013, 02:14 AM   #4
GOT FR-S
Drives: 2013 Scion FR-S (Firestorm)
I just installed the Rev Works header and Invidia Resonated top pipe today. Both simple and super easy. But the down pipe or over pipe (whatever you want to call it the one that connects the two and goes over the frame). We couldn't remove that piece at all and I had the car on a lift, but maybe if it was on jack stands it may have allowed the wheels to drop creating a little bit of room. But I doubt it..
Vortech SC. Rev Work Header, Perrin over pipe, Invidia resonated top pipe, Greddy EVO3 exhaust, Perrin Light weight crank pulley, Gofast bits lightweight waterpump & alternator pulleys, Perrin Trans & Shifter mount, MTec Shift springs. Cusco rear diff brace, 1pc Alum Drive Shaft (Drive Shaft Shop), ATC performance clutch & Flywheel, Whiteline Positive traction bushings. Grimspeed hood struts. EcuTek Tune.
GOT FR-S is offline   Reply With Quote
Old 04-28-2013, 02:49 AM   #5
cnk
Drives: '13 DGM BRZ Limited
If you take the heat shields off, the stock over-pipe comes out towards the back with a little twisting.
Sent from my Transformer using Tapatalk 2
cnk is offline   Reply With Quote
Old 04-28-2013, 02:53 AM   #6
Xdragonxb0i
Drives: ex500r
I had my car on ramps and use a Jack lift to lift the engine a few inches to get it out
Xdragonxb0i is offline   Reply With Quote
Old 04-28-2013, 03:00 AM   #7
cnk
No need to even jack the engine up if you take the heat shields off.
Old 04-28-2013, 07:42 AM   #8
tokiokun717
Drives: 2013 FR-S Whiteout
Are you getting it with the resonator or without? Because that makes a big difference. With the resonator you'll probably have to lift the engine a little (I've Experienced the install twice, one for mine and another for a friends and both required it).
With that said, the amount you have to lift is merely a couple inches max so you can get away with jacking the engine.
tokiokun717 is offline   Reply With Quote
Old 04-28-2013, 08:17 AM   #9
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
You can take out the stock overpipe without jacking up the engine. Just take off the heat shields and with a little bit of maneuvering you can take it out towards the rear. Installing an aftermarket overpipe will involve jacking up the engine though.
Tye300 is offline   Reply With Quote
Old 04-28-2013, 10:00 AM   #10
mad_sb
Drives: 2013 Asphalt FR-S
Specifically for the nameless over / front combo with the helmhotz you do have to lift the engine. I put the car up on jack stands (front and rear for ground clerance) then took out the one bolt on the bottom side of the mount on the passanger side then carefully jacked the engine up from the bottom side using my floor jack with a foot long 2x4 across teh oil pan IIRC. You will need to jack it up a few inches to get enough clearance to get the over / front pipe in position then you can let it down.
Do NOT waste your time removing heat shields... that will help you get out the stock over pipe, but you still have to lift the passanger side of the engine to get the nameless over / front pipe in place. So you may as well pull off the stock over pipe after you lift the engine and save yourself 15 minutes.
I did the whole install (not expecting to need to lift the engine) in just over 1 hour.
EDIT: I think i put the 2x4 across under the factory headers... anyway, use something to spread the load across the contact area and go slowly, should not be a problem since you are not supporting the whole weight of the engine.
Old 04-28-2013, 04:11 PM   #11
Sonolin
Awesome thank you! That's where my misunderstanding was, I didn't even realize you can just use a jack to lift it up (I thought you had to lift the entire engine up with an engine lift).
Sounds like a pretty easy install!
Old 04-29-2013, 02:36 PM   #12
GOT FR-S
Good to know! thanks, I work around it. lol. I eventually want to change that out as its the last stock pc on my entire exhaust system. lol
Old 04-29-2013, 02:43 PM   #13
mkivsoopra
I installed the Borla header and catted+resonated Nameless over/front pipe with the car on jackstands (front only). I did have to jack up the engine a few inches, and maneuvering the Nameless pipe into place was tight, but doable.
mkivsoopra is offline   Reply With Quote
Old 04-29-2013, 03:35 PM   #14
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Can anyone post a picture of where exactly the jack is when lifting the engine?
I had no idea about this.
Carlitoz3 is offline   Reply With Quote
Nameless Performance Overpipe/Downpipe Combo Jason@Nameless Engine, Exhaust, Transmission 277 04-04-2018 01:37 AM
Will nameless downpipe w/highflow cat fit with... Pandle Engine, Exhaust, Transmission 2 02-17-2013 08:13 PM
Nameless axleback and downpipe FS 117 Engine, Exhaust, Bolt-Ons 8 02-01-2013 11:06 AM
Differences between an overpipe/midpipe/downpipe? Tonym427 Engine, Exhaust, Transmission 1 08-10-2012 01:05 AM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 05:57 PM
