Old 04-29-2013, 11:23 AM   #1
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Custom BBK using Project Mu parts and EvoX brembo calipers
This weekend I went down to my friends shop in Tampa to have some mods done. The biggest one was a full custom BBK. I will be posting a full writeup on my site soon but for now here are some preview pics.
jadewbj is offline   Reply With Quote
Old 04-29-2013, 12:53 PM   #2
PMU teal on Brembos? This is almost blasphemy!
In for more info and the writeup!
Old 04-29-2013, 01:08 PM   #3
jadewbj
jadewbj's Avatar
I got approval from PMU, heck they suggested it.
Old 04-29-2013, 01:09 PM   #4
Squishy86
Squishy86's Avatar
Drives: Your Car
Its beautiful! This is the same set-up I was gonna go for.
Sent from my SGH-I777 using Tapatalk 2
Squishy86 is offline   Reply With Quote
Old 04-29-2013, 01:28 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What differences are there between the STI and EvoX Brembos?
Old 04-29-2013, 01:39 PM   #6
jadewbj
jadewbj's Avatar
The caliper is essentially the same. The back part with mounts is spaced slightly different hence why it does not line up and bolt on like the STI ones do.
Here is the full article on the process.
http://www.jadecrew.com/stop-like-right-now/
Old 04-29-2013, 01:44 PM   #7
OrbitalEllipses
Drives: Attitude
Same pad shape. Same pistons. Different thickness pads/rotors. Different mounting ears/points/pickups. Possibly an external fluid crossover, but I forget. Bleeders are mounted in the correct position as the Evo Brembo caliper is mounted in the leading position rather than the trailing position.
There's a thread on NABISCO about using Evo calipers. Possibly one on RS25.com as well.
Old 04-29-2013, 01:58 PM   #8
CrazyWookiee
Drives: Whiteout FR-S
If you search up for the FATLACE FR-S, they did this color scheme very early on last summer and everyone seems to have liked it so far.
Looks good in this color! I'd do it. Especially since you said you do have some PMU parts on.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 04-29-2013, 02:01 PM   #9
jamal
jamal's Avatar
Drives: Legacy GT
Big thing is that the mounts on the caliper don't line up with the holes in the upright. Notice how the article says it took a grinder, welding, and custom metal fabrication... no thanks. Do you really want to cut and weld something critical like the brake caliper or iron suspension upright?
Much, much better idea to just deal with swapping the bleeders on sti calipers.
I have a picture of the two next to each other around somewhere.
jamal is offline   Reply With Quote
Old 04-29-2013, 03:53 PM   #10
jadewbj
jadewbj's Avatar
Like I said, I would not recommend anyone else do it. Just get the STI calipers and swap the bleeders. Now the work done on my car is 100% safe, all done properly. Also it is not that far off so there was nothing major just a pain in the ass.
Old 05-01-2013, 04:19 PM   #11
mad_sb
Drives: 2013 Asphalt FR-S
Looks good but the color probably wont last if you track them. In the evo world we used to call them brownbo's... the super hardcore track cars had blackbo's after a couple seasons. That was a super easy way to tell if a car had been tracked hard or not.
Old 12-24-2013, 12:17 PM   #12
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Did you re-drill the rotor to 5X100 or you order them?
thx
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 12-24-2013, 12:20 PM   #13
jadewbj
jadewbj's Avatar
thx
I ordered 2004 STI Rotors, no drilling needed.
Old 12-24-2013, 12:27 PM   #14
B L U E S L A T E
Drives: BMW E84
Lots of work but end result is superb!
Sent from my Motorola Brick Phone
B L U E S L A T E is offline   Reply With Quote
Luck 86/FR-S/BRZ Project Parts Catalog kanundrum Engine, Exhaust, Transmission 58 05-24-2015 02:29 PM
Brembo + STD R9 dompower Brakes, Suspension, Chassis 17 06-13-2013 08:56 PM
Custom BRZ Parts for members gdi2290 BRZ First-Gen (2012+) — General Topics 56 10-07-2012 11:35 AM
How much would custom parts be? LexusFman Other Vehicles & General Automotive Discussions 10 07-23-2012 01:59 AM
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 04:35 AM
