Old 05-10-2013, 01:21 PM   #1
msile
msile's Avatar
Drives: ISF
APR Brake Ducts
Thanks to FT86-SpeedFactory for dogging APR until they shipped it.
Easy install. Clips into stock location. It also has two bolts that need to have nuts installed from behind the wheel well.
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
Old 05-10-2013, 02:20 PM   #2
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
How are you planning on routing hoses from the ducts to a rotor backing plate to make them functional?
Old 05-10-2013, 03:34 PM   #3
msile
msile's Avatar
Drives: ISF
Pretty simple. Just like I did for my Z06
Old 05-10-2013, 03:39 PM   #4
ATL BRZ
ATL BRZ's Avatar
I meant how you were going to route the hoses specifically from the back of the ducts to the wheel wells.
I'm not aware of a way to do so from that location.
I originally considered the APR ducts but there wasn't an established method of routing hoses to make them functional. I decided to get the @Touge Factory brake cooling kit which puts the ducts in the bumper opening to properly route the hoses around the radiator and into the wheel wells via the front control arms; the hoses safely clearing the wheels at full opposite lock steering angles.
The APR ducts look great but routing hoses looks like a pain if not impossible, especially with the stock washer fluid tank in place. There is not enough room behind the ducts in front of the wheel well liners. Touge Factory actually tried to make it work when developing their kit but wasn't able to.
Old 05-10-2013, 03:42 PM   #5
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
You cut a hole in the liner and route it through.
JDKane527 is offline   Reply With Quote
Old 05-10-2013, 03:46 PM   #6
ATL BRZ
ATL BRZ's Avatar
And then have the hoses get scraped off by your tires at speed and/or while turning?
Old 05-10-2013, 03:57 PM   #7
Hanakuso
It will never touch the tires if you route it right
Hanakuso is offline   Reply With Quote
Old 05-10-2013, 03:59 PM   #8
ATL BRZ
ATL BRZ's Avatar
OP, please keep us updated and post pics of your hose routing when you do it. I'm very interested to see your solution.
Old 05-10-2013, 04:02 PM   #9
sonnydelight
sonnydelight's Avatar
Drives: 2013 Scion FR-S - Whiteout
:happy0180:
sonnydelight is offline   Reply With Quote
Old 05-10-2013, 04:44 PM   #10
msile
msile's Avatar
Drives: ISF
Sorry. I misunderstood. Yes the routing will be a pain. I have a vortech kit, so my washer container is much smaller. Take a look at the Z06 pic. See the duct that the orange hose is connected to? In our case it has to be flush with the lining so that the wheel does not hit it. The duct hole has to end up in the middle of the tire so that the hose when bent will not interfere with the tire. I have couple of spare ducts that I am playing with. I cannot use the same diameter hose as I did in the Z06. I will have to go smaller.
So the idea is APR -> hose -> duct -> hose -> brake sheild
Old 05-10-2013, 06:26 PM   #11
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Please explain.
Most people that will be using a brake cooling kit will be running a much wider wheel and tire setup, which makes clearance between the wider tire and fender liner even smaller.
The only viable way of routing a hose to the rotor if using the fog light duct was to route the hose under the car and to the control arm. Not the safest or an efficient method to route the hose.
with a 18x9.5 +40 with 225/40/18 Advan Ad08, if you cut a hole in the front of the fender liner and try to route it inside of the fender well, one turn of the steering wheel will snag or rub on the hose.
Touge Factory is offline   Reply With Quote
Old 05-10-2013, 06:53 PM   #12
Touge Factory
Drives: ZN6
I could see this working, if you can get the ducting to be thin enough to snake along the inner liner.
We also tried mocking up an older piece we had for our evo and even at 1.5" thick with 245 tires - we couldn't go more then about a full turn on our steering wheels before making contact.
Old 05-10-2013, 08:17 PM   #13
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
I don't think our hounding did anything to speed up the process....but they did turn out fantastic.
Those look great!
Thanks Raj!
-Yo
FT-86 SpeedFactory is offline   Reply With Quote
Old 05-13-2013, 04:33 PM   #14
Touge Factory
Drives: ZN6
Those look great!
Thanks Raj!
-Yo
No hounding here.
Just offering our experience with what we tried.
BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC SOURCE,LLC Brakes, Suspension, Chassis 94 07-07-2013 11:56 PM
APR Performance Carbon Fiber Brake ducts! enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 16 06-01-2013 03:56 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
