Drives: 2014 SWP Limited BRZ
Estimated Max HP for a N/A setup.
Just like the title says, what do you think would be the max hp obtainable for a n/a setup on the FRS/BRZ.
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
Search. There is at least one 200+whp NA car.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
Drives: GT86
280-300 bhp or so. Good luck finding someone who can engineer that for you though.
Addicted
Drives: 2013 Asphalt FR-S 6MT
On ~92 octane gas probably around 195whp with I/E/H and a good tune. e85 gas probably higher. Keep in mind 195whp is a pretty liberal estimate, most people end up around 180-185, depends on the dyno.
Drives: 1980 corvette, 2014 Subaru BRZ
depends, do you want to do it with a FA20?
Red wine
Drives: Subaru BRZ(R.I.P)
Estimated max hp NA....If a 12 year old Honda K20 can hit 280whp NA, then this one can go for 280-300whp (optimistic but edgy).
#7 | |
Drives: 2013 Raven Black FRS
![]() I just saw a 200+whp dyno from another BRZ today...I'm sure it will be up soon! |
I'm asking because countless sources says that this car needs at least 40+ more hp. I'm wondering if this amount of hp (or even more) is attainable without having to go SC/TC and if so what type of modifications and how much $$ would it take.
(btw thanks for such prompt responses) |
Drives: E30 318IS
Definitely never going to reach k series power but for a max effort setup I can see 300
#10 | |
Red wine
But seeing as how high of a compression(12.5) we already have to start off with, and adding the Direct Injection to the mix and barely on an even ground with the K20 that dont even have any of these goodies. I am(for lack of a better word) scared, but hopefully future engineers can prove us wrong that this engine is a sleeping beast!
#11 |
Driveway labs.
We def. need cams for this motor.
I need to get a spare set of heads so I can drop them to Delta Cams
#12 |
Drives: BRZ - Dark Grey
always wondered... is it possible to swap to a k20? i thought I'd eventually find someone that did, but so far I haven't heard.
#13 |
Drives: 1992 Toyota MR2
Anything is possibly with the right hands and amount of money. Practically wise, the motor might be too tall and you gotta find a gearbox that will allow the motor to be mounted longitudinally. If I had to go through all that trouble, I'd figure a way to put the transmission by the rear axle to get the weight distribution closer to 50:50 or even better rear weight bias which is better than 50:50.
#14 |
Drives: 450 awhp twin turbo vr4
I would be more concerned about the Torque first, not the HP. Generally, anything over 200 HP and More will bring you up to 130 MPH no problem.
However, the Torque is what will move your car. Think about it this way Torque = Get moving HP = Top speed. Unfortunately, to change your Torque from an NA. You have no other options than swapping head, or cams. If not, then go FI such as Turbo or Supercharger. These cars will be fast, if you can put down 250 Torque at 1300 rpm, and 200 HP |
| Tags |
| max, setup |
| Scion fr-s options and estimated release date. | Fantum's86 | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 09-29-2012 04:09 PM |
| Scion fr-s options and estimated release date. | Fantum's86 | Hawaii | 1 | 08-04-2012 06:18 AM |
| Capitol Subaru-estimated arrival 6/8 | SuperSatinBrz | BRZ First-Gen (2012+) — General Topics | 78 | 06-07-2012 09:42 PM |
| Estimated HP gains - bolt on mods and reflash? | ahausheer | Engine, Exhaust, Transmission | 207 | 01-14-2012 07:14 AM |
| Estimated Price.. | SLeRoux92 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 05-25-2011 12:58 PM |
