Old 05-15-2013, 12:29 AM   #1
Chri5
Recommended Tire Pressure for Aftermarket Wheels and Tires
Any need to change tire pressure when running aftermarket wheels and tires? What are your thoughts? For reference, I'm running a square set up. Wheels are 18 x 8.5 and tires are 225/40-18 all around.
Thanks in advance .
Chri5 is offline   Reply With Quote
Old 05-15-2013, 11:26 AM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
..... this really depends on what you want to do with your car, how you want to change your handling dynamics etc
Who ever mounts your tires will probably have a decent idea what the general PSI would be. you can technically go with a lower PSI on a stiffer side wall etc.
Heck there is a vehicle out there that runs 12 PSI on its tires because it is so light...so PSI really depends on the vehicle set up.
Old 05-15-2013, 02:28 PM   #3
wparsons
wparsons's Avatar
I started with stock 35 psi on my new tires, but I kept them higher just to keep rolling resistance down. In general the more pressure you run the smaller the contact patch.
flickr
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 06:47 AM
Tire Pressure Warning pinoyplaya Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 12-21-2012 11:55 PM
M R Tire Solutions City of Industry = ENKEI WHEELS + TIRES + MUTEKI LUG NUTS MIKE@MRTIRESOLUTIONS Wheels and Tires 1 12-12-2012 01:57 PM
BEST TIRE PRESSURE TO RUN TRACK karma003 Tracking / Autocross / HPDE / Drifting 13 10-24-2012 06:32 PM
Are there any good/recommended aftermarket stereos? redwing634 Electronics | Audio | NAV | Infotainment 23 09-30-2012 03:29 AM
