Old 05-16-2013, 05:29 PM   #1
Chase86
Drives: Ultramarine FRS
TRD Exhaust/Intake Installed - Super loud - Problem or Normal??
I just had the dealer install a TRD intake and a TRD exhaust. Hard to tell any difference in performance because I'd only had it for a couple days/200 miles before that. One thing I do notice is that its really, really loud. I expected it to be louder but sometimes its so loud I don't really like it. I know loudness is relative but it drowns out the radio and you have to yell to hear the person sitting next to you.
Is that normal or did the dealer screw it up? They haven't done this to any other FR-S but it can't be that hard of an install.
Is there anything I can do to quiet it down?
Chase86 is offline   Reply With Quote
Old 05-16-2013, 05:32 PM   #2
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Delete the noise generator or buy a TRD sound changer (green is quiet I think)
RandomHero is offline   Reply With Quote
Old 05-16-2013, 05:35 PM   #3
Chase86
The TRD Intake doesn't use the noise generator, it gets capped off.
Old 05-16-2013, 05:38 PM   #4
tennisfreak
Drives: 2018 BMW M240i
I think your exhaust may be loose and/or have a leak somewhere.
I have the TRD intake and a Perrin Non Resonated catback exhaust (which is louder than the TRD exhaust) and my car does not drown out the radio or require me to yell at the person next to me.
Does it sound like everything is coming from the rear of the car or does it sound like some of the noise is coming from underneath you?
Old 05-16-2013, 05:45 PM   #5
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Oh good call on that one! I havent looked at a TRD intake in weeks. The TRD stuff is designed to be quiet street friendly so it really shouldnt be loud enough to drown the cabin in noise.
Old 05-16-2013, 05:46 PM   #6
Chase86
I'm pretty sure there is sound coming from underneath me.
Old 05-16-2013, 05:48 PM   #7
tennisfreak
Well then that makes the problem pretty clear if its coming from underneath you.
Most likely the connection between the down pipe and the midpipe is loose or missing the gasket. (worst case there is an actual leak because of a hole or broken weld).
I'd take it back to the dealer and have them fix it.
Old 05-16-2013, 05:50 PM   #8
Chase86
Thanks for the feedback. I thought maybe I was just turning into an old man but it seems like I might have a problem. I'll stop by the dealer on my way home today.
Old 05-16-2013, 05:57 PM   #9
Mikem53
Drives: FR-S 6MT
Tennisfreak is right.. shouldnt be that loud and probably an install issue.
Have a listen to some of the recording on this forum and you will get an idea of what it should be like..
I am considering the TRD because its on the quiet side with just a low tone and no drone.. according to what I have researched..
Mikem53 is offline   Reply With Quote
Old 05-16-2013, 06:01 PM   #10
Mikem53
Drives: FR-S 6MT
keep us updated.. so far you are the only one to think its too loud.. i also know thats a subjective issue.. let us kniow
Old 05-16-2013, 11:31 PM   #11
ChristosG
Drives: 2013 Scion FR-S Hot Lava 6MT
Mine sometimes gets loud on the highway when I'm just over 3000 rpm. It only happens in a small rpm range (3100-3200) but that's where I am in 6th on the highway.
ChristosG is offline   Reply With Quote
Old 05-17-2013, 08:24 AM   #12
kevman_101
Drives: 2013 Scion FRS
I have a TRD cat back too and it's really only noticeable when taking off and full throttle. Other then that, even at highway speeds +10-20 kph, it's pretty quiet. Hold a conversation still at regular levels and not shouting like I used to in my Sentra.
If it's loud and you hear rasping, or straight pipe sounds, there is a leak.
kevman_101 is offline   Reply With Quote
Old 05-17-2013, 09:24 AM   #13
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
I have TRD in/ex and it is by not very loud... Sounds like you've got an ex leak.
The only time mine is "loud" is when I first start it up when it is cold.
Thorpedo is offline   Reply With Quote
Old 05-17-2013, 12:34 PM   #14
Chase86
Problem Solved!
I went to the dealership last night and had them check it out. After a quick ride they agreed that it didn't sound right. So they took a look under the car and found that the bolts holding the exhaust together had come loose and fallen out. You'll have to excuse my lack of knowledge but it was at the beginning of the exhaust where it connects basically where the firewall is. So I was getting straight engine noise right under my feet. Its hard to describe but it was so loud it was mind melting.
So they tightened it all up and it sounds SOOO much better! Not too loud just a nice deep tone coming from the back! I love this car! Only another 500 till she's broken in.
I really appreciate all your feedback on this one!
Loud exhaust / Buddy Club Spec II exhaust help! chiefshayan Engine, Exhaust, Transmission 26 12-06-2019 06:59 PM
Loud popping in the intake Yruyur Engine, Exhaust, Transmission 72 02-22-2015 03:11 PM
Installed exhaust and Intake, pedal dead spot. How long does it last jflogerzi Engine, Exhaust, Transmission 24 02-23-2013 06:11 PM
Not sure if this is a problem or something normal... frosty86 Issues | Warranty | Recalls / TSB 1 10-05-2012 09:36 AM
Super Low, Normal, Medium, and Hyper? EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-19-2012 03:42 PM
