Unable to hold idle.
Has anyone else had this? Engine is 100% stock.
[ame="http://www.youtube.com/watch?v=450Pov98STg"]BRZ bad idle + misfire, no CEL, stock engine - YouTube[/ame] |
Proud of FR Layout
Drives: 2013 Scion FR-S 6MT
mine only seems to do it when its hot out and Im running the a/c. Definitely something you should have a dealership look at for warranty work. Ive been too lazy to take mine in though.
Drives: SWP BRZ 6MT
I've been fortunate to only have an idle dip issue when there was a small leak in my pcv system after installing a catch can (ID10T error
).The video seems to show the symptoms described as part of the infamous P0019 cel issue, just without the actual cel so far. Assuming this is your BRZ, you've had it for a while, has it ever had the ecu reflash? |
Drives: 2013 BRZ Limited - WRB, MT
mine will do it but not that frequent; maybe once while i'm stopped. I do always have the auto climate control on though so that could be contributing to it
This was happening somewhat permanently, and is much more extreme than the idle dip that was happening previously.
You can actually hear a misfire most of the times when the RPMs dip, and the jump up is fairly large. The previous idle issue happened once every ~15-20 seconds, and it was fairly quick. This is consistent, and constantly fluctuates, almost like a cammed civic, but with a slower oscillation. |
#6 | |
Drives: Attitude
Drives: Moped
The CEL is coming, its just a matter of time. Do you have a scan tool/datalogger to see what is going on with the car when the idle jumps/drops and the knock occurs?
What are you guys doing to those motors at CSG (this could be number three, right?) pissing in the gas tank?
Now with Boost!
Drives: 2013 SWP BRZ Ltd.
The only thing it's missing is the idle shaking/shuddering...couldn't tell from the video.
When it CELs, take it to the dealer and leave it there until they're done with it. |
Drives: Subaru BRZ 6MT LTD
Take it in to the dealer asap man, get your ecu flashed there to the latest.
#10 | |
Drives: BRZ(sold), STI
#11 | |
Drives: Moped
Then again, I don't completely understand the nuances of newfangled direct injection fueling, timing, and spark tables, or the variable everything that seems to be on motors these days. Sometimes I miss the simplicity of working on my dad's 66 Mustang. It just seems like the car is missing. That's why I would love to see some logs at various loads and at idle... |
#12 |
#13 | |
Drives: FR-S 6MT
#14 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
TPMS light is on. If this is not real then it is one of the indicators of an ECU problem.
| Will these cars hold up to high mileage? | wbradley | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 04-02-2013 03:05 PM |
| How to get a hold of Subaru of Canada? | chenshuo | CANADA | 10 | 02-21-2013 02:23 AM |
| Track Video: BRZ Passes worked Miata, unable to be passed by prepped s2000 | gmookher | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 11-06-2012 02:01 PM |
| I think we hold the record for most different wheels installed on an FRS ;) | WheelDude.com | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 09-24-2012 03:39 AM |
| Subaru, Audi, M-B hold value best | Axel | Other Vehicles & General Automotive Discussions | 4 | 01-14-2010 10:12 PM |
