Old 05-29-2013, 10:51 AM   #1
AL008
Drives: Celica 04
Atermarket Speaker crossover install location
Hey guys,
Just wondering what are the options of where we can install the speaker crossovers?
Thanks.
AL008 is offline   Reply With Quote
Old 05-29-2013, 02:23 PM   #2
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
To do it properly, probably this:
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
Old 05-29-2013, 02:30 PM   #3
mid_life_crisis
Drives: FR-S 10 #103 AT
How hard was it to snake all those wires to the door?
Old 05-29-2013, 07:20 PM   #4
AL008
Drives: Celica 04
I saw your guide for your audio installation. Did you have to drill holes into the door?
I am kind of thinking a location where it doesn't have to move alot, like inside the vehicle rather than on the door itself.
Thanks.
Old 05-29-2013, 08:20 PM   #5
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Thanks.
Not sure how much room is in the dash, what about behind the passenger dash panel? Under the dash speakers? Under front seats? Just some thoughts.
On my WRX, I did pretty much what Brian posted, but used existing wiring to the xovers so I didn't have to fish anything through the doors (tweets on the doors, too).
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-29-2013, 10:13 PM   #6
cruzinbill
Drives: Argento 6spd FR-S
Id put them in the trunk and run a fresh run to the mid and tweeter. Then, if you ever go active, the hard work is done.
Plus its easy to get to any jumpers the xovers have, since you need the door panels on to tune correctly.
cruzinbill is offline   Reply With Quote
Old 05-30-2013, 10:20 AM   #7
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
I tend to tuck them away under the dash compartment right above the footwell. If you're using the stock tweeter/woofer placement this would make running all the wires pretty simple.
However, if you move the tweeter to the door panel then I would put them behind the door panel (do not put them in the actual door behind the plastic).
rmjjensen is offline   Reply With Quote
Old 05-31-2013, 12:29 AM   #8
mashal
DADA
mashal's Avatar
Drives: 2013
I have mine tucked in the kick panels. I like to change things up a bit every now and then so I need access and didnt want to take the door panel off.
A couple of tie wraps and they dont move
mashal is offline   Reply With Quote
Old 05-31-2013, 02:02 AM   #9
HotSauce
Drives: 2013 Scion Fr-s Firestorm
I just finished my install and the wires to the doors are some of the more difficult I've worked with. In order to run the wire thru the grommet it requires removing the tape holding the two boots together then snaking the wire past the bottom of the top boot, cutting a hole for the wire to poke thru the bottom boot before reinstalling the top boot and re-taping it. Sounds confusing but if you attempt this it'll probably make more sense... Not to mention it took me FOREVER to reattach the boot to the car, but it was worth it!
I decided to go with the alpine type R's partially due to the very small crossovers, about 1" by 1" by 2", but in the end I ran them active and didn't use them. Either way I am very pleased with the sound and would recommend either set-up, active or passive.
HotSauce is offline   Reply With Quote
Old 10-18-2016, 12:37 AM   #10
Here2rock
Drives: 86 GTS
Any pictures how you did this? Do you mean the existing kick panel in the car? It is big enough to hide the crossover?
Here2rock is offline   Reply With Quote
namess vs AP crossover pipe? thebear21 Engine, Exhaust, Transmission 92 08-15-2013 07:38 PM
Spot to hide crossover ?!!! mashal Electronics | Audio | NAV | Infotainment 1 12-18-2012 01:00 AM
Oil Cooler Location? Captain Snooze Engine, Exhaust, Transmission 5 11-26-2012 06:02 PM
Factory amp crossover specs JoeBoxer Electronics | Audio | NAV | Infotainment 0 09-23-2012 10:09 PM
