Old 05-31-2013, 12:23 AM   #1
Gwest11
Gwest11's Avatar
Drives: Stock 2013 Ultramarine Scion FR-S
Exhaust options for 13' FR-S?
I'm really into the throaty sound of the GReddy Evo 3 exhaust and I still want to keep my options open. Which exhaust do you guys have and how much do you like the idol tone, high rev sound, in car sound, etc. But since I dont know a lot about cars I want to get the opinion of other FR-S/GT-86/BRZ owners. I'm 18. It was my graduation present and I want to start doing work on my car. I like the set up of the GReddy Evo3 exhaust with GReddy momentum intake and Borla Headers. (Eventually get a lightweight crank pulley, and later LATER in life get a supercharger still don't know which one though)
Gwest11 is offline   Reply With Quote
Old 05-31-2013, 12:24 AM   #2
oTaGGeDo
oTaGGeDo's Avatar
Drives: Currently driving a 2013 turbo Tc
Use the search function and I recommend you checkout Dsport magazines exhaust shoot out good luck also try unbolting your stock muffler there are two bolts
oTaGGeDo is offline   Reply With Quote
Old 05-31-2013, 12:28 AM   #3
Gwest11
Gwest11's Avatar
What would unbolting the stock muffler do? Any side effects, sensor trips?
Old 05-31-2013, 12:33 AM   #4
oTaGGeDo
oTaGGeDo's Avatar
No sensors nothing just pure greatness with $0 cost just do it and enjoy you will thank me later and get acquainted With the dang search button lol
Old 05-31-2013, 12:34 AM   #5
oTaGGeDo
oTaGGeDo's Avatar
Crawl under rear of car look up to your right you will see two bolts I wanna say they are 14 mm unbolt remove muffler enjoy
Old 05-31-2013, 12:34 AM   #6
Gwest11
Gwest11's Avatar
Lol well thank you man. Much appreciated. See you in the forums
Old 05-31-2013, 12:37 AM   #7
oTaGGeDo
oTaGGeDo's Avatar
Your car also loses 30 pounds if you don't like how it looks Berk makes a muffler delete that bolts up to it I did the single because of weight it's. $150 or you can just run with no tip it's not necessary just purely cosmetic Berk also makes a dual but it will quiet it down I'm all about light weight bedside I auto x my car take your car to a local auto x event and I guarantee you will forget mods and just wanna learn to control what you have
Old 05-31-2013, 08:11 AM   #8
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Didn't someone unbolt his muffler and melt his bumper off?
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 05-31-2013, 08:31 AM   #9
CaptainSlow
CaptainSlow's Avatar
I had just a Berk dual-tip muffler delete. Was pretty loud inside the car, especially while driving around town normally (like in the 1800-2200 RPM range). I then had an 18" Vibrant resonator welded in the pipe between the two tips. That quieted the exhaust down quite a bit, especially in that RPM range I mentioned earlier. The only issue with it now is that the drone sort of moved up to the 3500RPM range, which is where it sits doing 80mph on the freeway. The drone is noticeably quieter than it was without the resonator, but it's still there. It does seem to go away slightly after spending some time there - like it seems louder when just getting up to speed than it does a half hour later (not sure if the noise level is actually changing or if I just get used to it after a while).
Anyway, it's a good setup if you're on a budget and can deal with a bit of extra noise in the car. If you're looking for complete quiet inside the car, I'd just change the tips on the stock muffler or go with one of the more expensive cat-backs.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
evo3, exhaust, greddy, sound
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 10:14 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 11:07 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
