Old 06-02-2013, 02:42 PM   #1
abling2
Drives: toyota gt86 firestorm red
what is your tire pressure?
what's your tires specs and how many psi do you have in your tires?
thanks
abling2 is offline   Reply With Quote
Old 06-02-2013, 02:54 PM   #2
Noke
Noke's Avatar
I put factory specs. If I'm correct they are 25 ... Or 35. When I got them from the dealership it was at 50 psi ... Crazy
No rest for the wicked.
Noke is offline   Reply With Quote
Old 06-02-2013, 03:30 PM   #3
abling2
I have 255/35/18 specs.. I have 40 psi on all four of them.. is that safe? thanks
Old 06-02-2013, 04:16 PM   #4
Noke
Noke's Avatar
I believe it's safe as long as u don't go over the limit which is 50psi. But when I was running with 50 the car didn't have much feel on the tires, felt like my car was just gliding ... When I dropped it down 30 it felt more connected to the ground hence more rubber touching.
Old 06-02-2013, 04:21 PM   #5
Tiremonkey0824
Drives: 2013 Argento 6mt
I wouldn't say this is dangerous but there is no reason to run them that high. You could wear your tire unevenly over time. I would run the anywhere between 32 and 36.
Tiremonkey0824 is offline   Reply With Quote
Old 06-02-2013, 04:36 PM   #6
Barbarian
Barbarian's Avatar
Drives: Raven FR-S
It depends. I wouldn't say it's unsafe, but it's also not as safe as a lower psi because the lower psi will have more rubber touching the road so you will have more control over the tires. I wouldn't go any lower than the manufacturer recommended amount though unless you have some very specific reason and know what you're doing.
Barbarian is offline   Reply With Quote
Old 06-02-2013, 04:38 PM   #7
whaap
whaap's Avatar
When I air up cold I usually go 2 lbs. over what shows inside the door.
whaap is offline   Reply With Quote
Old 06-02-2013, 05:08 PM   #8
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
35 here. Plus don't forget if you do a lot of highway driving on summer to go down on the pressure a bit since excessive heat increases tire pressure and you don't want it increasing to over 55-60, too dangerous.
Yamajee is offline   Reply With Quote
Old 06-03-2013, 08:09 AM   #9
abling2
i changed my tire pressure to 37psi on all four.... thanks guys
Old 06-03-2013, 11:49 AM   #10
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
I don't see why people would think 40 is too much. The tire is rated for a max of 50. If you put too low of pressure in the tire, it will start cupping and wearing unevenly. Cupping occurs when the outside edges of the tire wear down and the center part doesn't. My tires are around 32 now I think, but I am going to bump them up to 40.
Lower tire pressure also makes your car slower to accelerate and lowers your MPG.
Freetime is offline   Reply With Quote
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 06:47 AM
Tire Pressure Warning pinoyplaya Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 12-21-2012 11:55 PM
Tire pressure of all-seasons Scoob Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 11-12-2012 01:49 AM
Tire pressure warning on sa1126 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-27-2012 09:26 PM
BEST TIRE PRESSURE TO RUN TRACK karma003 Tracking / Autocross / HPDE / Drifting 13 10-24-2012 06:32 PM
