Old 06-03-2013, 10:46 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Relocating Battery to trunk
I have/will have lost about 60-70 lbs of weight from the rear of the car and I thought that maybe it would be appropriate to move the battery to the trunk, and placing it in the spare tire well. This will even out the balance in place of the rear missing weight since the front is already heavier than the rear.
I'm thinking 8-6 gauge wire for the job, including ground. If I get everything working right I will post a log/diy. Any thoughts, concerns or details I'm missing? Since I usually do.
Old 06-03-2013, 10:52 PM   #2
EN2_Squirrel
EN2_Squirrel's Avatar
sub'd
EN2_Squirrel is offline   Reply With Quote
Old 06-03-2013, 10:59 PM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
Might be easier to buy a lightweight replacement and leave it up front, depending on budget.
Old 06-03-2013, 10:59 PM   #4
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Subbed as well
Old 06-03-2013, 11:03 PM   #5
ML
ML's Avatar
I agree 100%, it would be easier
Old 06-03-2013, 11:05 PM   #6
xwd
Unless you need space it's just not worth it versus just getting a lightweight battery. You will add weight with the cables which at a minimum would be 4 gauge. It's not like the battery is mounted way in front like the Imprezas, it's right next to the firewall...
Old 06-03-2013, 11:12 PM   #7
ML
ML's Avatar
[ame="http://www.amazon.com/Cadence-4G150-BLUE-Gauge-25-Technology/dp/B005PIMEP6?t=slickdeals&tag=slickdeals&ascsubtag=A BreOsy8EeKJBu4ky_MqHA0_qsai2_0_0_0#productDetails"]Amazon.com: Cadence 4G150-BLUE 4 Gauge 25 Foot blue Amp Power Wire Spool w/ Cool Cable Technology (Cut from a 150 Foot Spool): Car Electronics[/ame]
just a quick search (probably not the most accurate source, but just for discussion) shows that 25 feet of 4 gauge copper only weighs 2.2 lbs, so I don't think the added weight of wire is really a concern to me.
Old 06-03-2013, 11:47 PM   #8
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
My battery Only weighs 1.5 lbs.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 06-03-2013, 11:49 PM   #9
ML
ML's Avatar
I get that it would be WAY easier to just plop a d-cell sized battery in there, but what is hard is convincing my wife.
Old 06-03-2013, 11:50 PM   #10
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I think the trouble of moving the battery all the way to the trunk is wasted when you can buy a 5lb battery for a few hundred bucks. I mean 2.2lbs of wire? That's almost half the weight of my battery br0! Take weight off the front of the car if you want to balance it. Or keep the gas tank full. Or fab up a proper rear diffuser. JMO.
edit: money/wife eh? Should prob still get a sealed battery since it'll be in the cabin now.
industrial is offline   Reply With Quote
Old 06-04-2013, 12:07 AM   #11
Simmons
Simmons's Avatar
Mine was only $140
Simmons
Old 06-04-2013, 12:34 AM   #12
BlueDubbinTDI
Originally Posted by Simmons View Post
Mine was only $140
Simmons
Link?
Old 06-04-2013, 11:57 AM   #13
xwd
You can't really put the stock lead acid battery in your trunk unless you want to put it in a battery box with a vent tube. Now there are conveniently a bunch of holes which run from inside the trunk to the frame so that might work out okay, but I wouldn't consider it ideal. Almost everyone I've ever seen relocate a battery inside (include myself) uses a sealed AGM battery.
Old 06-04-2013, 12:04 PM   #14
Mikem53
Drives: FR-S 6MT
This ^^^^^.
Mikem53 is offline   Reply With Quote
Relocating from Hawaii BrzRacer Northwest 48 04-14-2013 05:15 AM
relocating the 3rd brake light Basti Cosmetic Modification (Interior/Exterior/Lighting) 6 03-06-2013 07:08 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
Battery in the trunk scottman Electronics | Audio | NAV | Infotainment 14 10-06-2012 08:26 PM
Relocating battery to trunk Ess Vee Engine, Exhaust, Transmission 17 10-02-2012 05:32 PM
