Old 06-08-2013, 02:03 AM   #1
xdbuix
Drives: 2013 Galaxy Blue Limited BRZ
reverse lights
Basically, I got rear ended by another driver. One of my reverse lightbulbs came loose and is sitting around in the lightbulb housing area. Any suggestions on how I can get to the bulb out so I can reinstall it? Thanks!
2013 Galaxy Blue Limited Subaru BRZ
DEAD 1994 Camry 9-21-2012
xdbuix is offline   Reply With Quote
Old 06-08-2013, 02:09 AM   #2
ft86me
ft86me's Avatar
Drives: 2013 FRS
well if you can get the rear peice off you could take some small needle nose and get the bulb to center by the hole and maneuver it to come out. otherwise, it's going to be pretty tough without being able to move that housing around.perhaps a very fine 90 degree pick with something VERY sticky at the end will work? harbor freight has pick sets for stupid cheap
ft86me is offline   Reply With Quote
Old 06-08-2013, 03:11 AM   #3
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
well... best just take it off and shake it out. but if you want to try something different, make a straw noose. just make a loop that goes through a straw. dip it into the hole and fish for the bulb. once the string is around the base, pull on the string to close the loop.
mrlewistan is offline   Reply With Quote
Old 06-08-2013, 03:35 AM   #4
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
Open the trunk. There are four nuts if I remember. Take them off and be careful not to let them drop because they will end up in your trunk lid. (Not that I would know this. You can then take off the piece that has the Scion emblem and from there you can reach the mounts for the license plate lights. Do what you need....I just re read your post. Sorry. Open the trunk. Take out your trunk mat. Remove the plastic rivets from the center piece. Remove said piece. There will then be 2-4 more on the side piece. You can then fold it back. Use a 8mm socket to remove the nuts from the tail lights. You will also need to remove one or two wire mounts that attach to the bolts on top of the nuts. Carefully remove the tail light and be sure to unplug it from the wiring harness. Once out, you can then remove the reverse light bracket and fish out the bulb. When you install everything be sure that you tighten the nuts onto the assembly pretty good. Don't break them but if they are loose you end up with moisture in the tail light. Good luck.
Customize the piss out of it and call it yours!
Skywgn1 is offline   Reply With Quote
Old 06-08-2013, 03:42 AM   #5
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
the reverse lights are not part of the tails. the tail holds running, stop, and turn signals. the reverse light is down in the center of the bumper to each side of the red triangle reflector (or rear fog light on the brz)
Old 06-08-2013, 03:43 AM   #6
husker741
Something similar happened when I installed my switchbacks. The bulb fell into the housing and I could not get it out. Well, it was late and my dad had a grand idea. He said to take the gum out of my mouth, put it on my finger, stick it to the bulb, and carefully remove it. It worked. Orbit gum isn't only about keeping your teeth clean anymore.
husker741 is offline   Reply With Quote
Old 06-08-2013, 03:52 AM   #7
Skywgn1
Skywgn1's Avatar
Dude, my bad. Open your trunk. There are two 10mm bolts that need to come out next to the tail lights. While in the trunk, remove the center piece as stated above. I also removed the tail lights. Now, you will need to go to the rear wheel and remove the rivets that are high in the wheel well (follow the rear bumper seam to the wheel well and you will see it. Now go below the car and start removing rivets starting at the rear wheels and working your way to the center. If I remember there are two pretty close together buy the wheels on each side and then two in the center that attach to a bracket by the center of the muffler. There are a few smaller rivets but can stay. Then start pulling the bumper off at the wheel well and work your way to the center. The center has metal clips but the bumper will slip away from them. Then look at the revers light assembly and you will see two more rivets on either side of the assembly and two 10mm bolts. Take them out and it will swivel down. It is attached at the bottom but can be forced off of this. Remove the reverse light harness and you can get the bulb out. Then reinstall in reverse order. Sorry about the confusion. It's 1 am and I'm really tired.
Old 06-08-2013, 10:54 AM   #8
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
you're lucky the gum didn't fall off your finger haha
mezdup is offline   Reply With Quote
Old 06-11-2013, 11:00 AM   #9
xdbuix
thanks guys for the suggestions!
What I did was I rattled the lightbulb until it positioned itself in front of the hole. I then used some long pliers to pull it out. Not going to lie, it was a big pain in the butt, but I got it done.
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 08:42 PM
Water in reverse lights roddy Scion FR-S / Toyota 86 GT86 General Forum 30 05-09-2013 10:18 AM
Reverse Back-up lights mit_peid Electronics | Audio | NAV | Infotainment 2 05-04-2013 08:04 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 09:38 PM
GTA: CREE Reverse Lights Selvedge Canada Classifieds 0 12-27-2012 07:37 PM
