Old 06-10-2013, 12:38 PM   #1
Bullnettles
Drives: Scion FR-S 2013
Manifold nut size
Starting a new thread since the one I was in was resolved. I had one of the six nuts vibrate loose and is gone. Just got this schematic from the dealership and I'm in the same boat as the tech; it doesn't look like it's on here. If anything, it MAY be the SU003-0051. Thoughts?
Bullnettles is offline   Reply With Quote
Old 06-10-2013, 02:08 PM   #2
Hardrock4445
Hardrock4445's Avatar
I don't see it on that diagram. Remove one and match up at hardware store and just put a regular and lock washer on it and you should be fine.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 06-10-2013, 08:00 PM   #3
FirestormFRS
It's #2 since there is no corresponding bolt with that nut.
FirestormFRS is offline   Reply With Quote
Old 06-10-2013, 08:33 PM   #4
Hardrock4445
I believe #2 is the small nut to hold the heat shield on. Look at top left. There is one there too near that part of the shield.
Old 06-10-2013, 08:38 PM   #5
OrbitalEllipses
Drives: Attitude
#2 is a heat shield nut those come have a 10mm head; which nut vibrated loose?
Old 06-11-2013, 01:02 PM   #6
Bullnettles
I believe you are correct; it appears to mate with #1. The locknut that holds the header to the motor on one of the three studs near the exhaust ports.
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 02:43 PM
Anyone going to paint their manifold covers? quik1987 Cosmetic Modification (Interior/Exterior/Lighting) 64 07-30-2014 03:39 PM
WTB Turbo manifold evanmd Engine, Exhaust, Bolt-Ons 0 06-02-2013 08:02 PM
'Induction Roar Manifold Tube' White64Goat BRZ First-Gen (2012+) — General Topics 1 04-28-2013 07:51 PM
Need factory exhaust manifold dorifuto Engine, Exhaust, Transmission 1 01-24-2013 02:05 PM
