Old 06-10-2013, 04:11 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Thumbs up Quick Comparo>>> Perrin vs. Motiv Overpipes
Hey everyone, we picked up Motiv Concepts products not too long ago and got some of their products in house. We are highly impressed by the quality of the products they are producing. Big thumbs up to the guys over at @MotivConcepts
Just wanted to take a quick minute to compare the Motiv Concepts overpipe with the Perrin Performance overpipe. We took some side by side photos and glanced over some of the minute differences in the two products. Perrin quality is very tough to beat and that is the same case here, but Motiv just takes a couple extra steps to ensure that there are no corners cut on their overpipe.
Notice the extra weld on the inside of the flanges on the Motiv piece along with the outside weld on the flange. Both pieces have their added bits of flair with the Perrin having a branded flange and Motiv having a printed plaque with serial number tack welded onto their piece.
Other than that, the only other difference is what else you get in the box and the ~$30 you keep in your pocket from going with Motiv. Some reasons why the Perrin costs more???
1.) Flanges are CNC machined from 1/2" 304ss to reduce warpage and leakage over a long life.
2.) Flanges have a CNC'ed inside lip to compensate for the thickness of the tube. This eliminates the inside lip that can cause air flow disturbance.
3.) They use expensive OEM grade multi layer crush gaskets for a sure seal that will last.
Onto the pictures
Motiv piece
Perrin piece
Side by Side
Notice the weld on the inside lip, again the attention to detail is amazing here with Motiv.
FT-86 SpeedFactory is offline   Reply With Quote
Old 06-10-2013, 06:40 PM   #2
Ingen
Drives: Ultramarine FR-S 6MT
Everyone on this forum seems to chat up "beautiful welds" whenever new exhaust hardware gets posted.
The welds on the motive piece here are something to aspire to, truly. Those are good welds.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 06-23-2013, 10:59 PM   #3
FT-86 SpeedFactory
Both items are great parts. Just wanted to show them side by side really as you never get the opportunity to see them that way.
Old 06-23-2013, 11:16 PM   #4
charged86
charged86's Avatar
I have the motiv. now seeing side by side it appears to have less angles than perrin
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-27-2013, 06:53 PM   #5
charged86
charged86's Avatar
oh and I would like to thank motiv for all the nice add on stuff and swag I got with the pipe.
new bolts
new gaskets
warranty card
and a sweet ass tshirt.!!!!!!!!!! which im wearing right now. @MotivConcepts
Instruction sheets
Old 06-27-2013, 07:30 PM   #6
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I forget the technical term but the Perrin piece almost looks like the welds on the flanges were done by doing individual little spots all the way around as opposed to properly working the bead. Rather large divots between each "dime." Might not be the case, but the Motiv definitely has the superior welds of the two. I'm sure functionally both are fine.
Nathan
SubieNate is offline   Reply With Quote
Old 08-10-2013, 07:37 PM   #7
noob and expert
Drives: None :(
so which is better? the Perrin has better gaskets but the motiv has better welds? how do you chose?
??? is offline   Reply With Quote
Old 08-10-2013, 08:25 PM   #8
tennisfreak
Drives: 2018 BMW M240i
I would not necessarily say the welds are "better" in terms of how they will hold up. The welds are definitely prettier but the Perrin is welded damn good.
With Perrin you have
With Motive you have $30 extra bucks and still a damn good product.
Hard to not recommend either.
Old 08-11-2013, 01:36 AM   #9
ft86me
ft86me's Avatar
Drives: 2013 FRS
I personally want to chime into this here. Yo, over at f86speedfactory got me into the motiv concepts with my hks el header setup. I was slightly worried because I haven't heard about motiv, but holy wow for the money that your paying vs the quality, the motiv concepts looks EFFIN AMAZING in person! The fit is perfect too! my muffler guys that installed my motiv overpipe and front pipe were saying that it was a perfect fit!
For those of you that are worried about the overpipe rubbing on the subframe or sway bars, which I'm running the cusco thickest sway bar, there is enough clearance that you can shove your fist in there. Motiv FTW!
just fyi, my setup thanks to ft86speedactory, hks equal length header, motive overpipe, motive front pipe and ark grip catback. perfect fitment.
ft86me is offline   Reply With Quote
Old 08-11-2013, 01:56 PM   #10
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Not owning ether, but leaning to Perrin. Both are works of art!! You could have ether on a coffee table as a conversation piece.
skye67 is offline   Reply With Quote
Old 08-11-2013, 02:02 PM   #11
Kagetsu
Drives: 86 GTS
Just want to pipe up regarding the Motive over pipe. It's a quality item, but I have concern with the double weld on the inside of the flanges and the outside of the flanges. This 'may' be of concern as a cracking point from thermal expansion leading to fatigue over time. This may not be of concern in the lifetime of the car for 99% of people, but it was a slight concern to me. Please note, I'm not suggesting it's a poor quality item, it's excellent quality, just keep that in mind.
Kagetsu is offline   Reply With Quote
Old 08-11-2013, 04:27 PM   #12
noob and expert
Drives: None :(
and is there any difference in the sound?
Old 08-11-2013, 05:26 PM   #13
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Would be interesting to check weight of the both pieces on the same scale. Also, very interested which one allows more clearance vs. the front sway bar. If anyone had experience with installing both - would be very interesting to hear!
Efferalgan is offline   Reply With Quote
Motiv Front Pipe and Perrin Catback Vukodlac Engine, Exhaust, Transmission 16 06-19-2014 06:26 PM
FS: Motiv Concepts Test Pipe, Overpipe, Perrin Inlet tube JoeBoxer Engine, Exhaust, Bolt-Ons 5 03-31-2013 03:57 PM
Borla, Motiv Concepts, Perrin all on sale. Headers, intakes, exhausts JoeBoxer Engine, Exhaust, Bolt-Ons 0 03-28-2013 12:05 AM
Quick review to my perrin CAI, installation, and Results 3askoul Engine, Exhaust, Transmission 0 03-12-2013 04:33 PM
My FRS baseline VERSUS Visconti e85/Perrin/Injen/Motiv setup TyperRspec789 Engine, Exhaust, Transmission 15 12-24-2012 09:10 PM
