Old 06-11-2013, 07:48 AM   #1
GaDgeT
GaDgeT's Avatar
BRZ Custom SQ Audio Install
Hey guys
Just picked my ride up from the installers and have finally finished up my audio build.
Kit list as follows:
Headunit
Pioneer App Radio 2
Inputs
Kiwi PLx OBD2 wifi link
GPS, Bluetooth
Iphone via dock
Reverse cam
ebrake bypass
Processor
Alpine PXA H100 with RUX controller
Amps
Eclipse XA1000
Eclipse XA2000
Arc Audio Mni KS 125.4
Speakers
Front - Active 3 way Hybrid Audio drivers
L1 Pro
*L3SE
http://store.12velectronics.com/prod...eaker-Set.html
L61-2
Sub
Boston Acoustics G3
Massive props to Phatt, who have done nothing but epic install and got all the go louds bits to work.
Build request was pretty simple, stealth install of speakers and amps into factory locations, keep the tools, lose the spare tyre, quick release sub box and minimal sound deadening to keep it light for track days.
As a daily, I wanted to retain as much space as possible for snowboard, clubs, bodies and large quantaties of cash / drugs.. this car is so versitile ;p
The car will be doing the rounds on the audio comp scene in the coming months, will see if the $$ + SQs ;p
Install pics from go to whoah!!
Final boot install
With stealthy cover
Factory vs Hybrid tweeter upgrade
Grills needed to be ground back, and hex trim removed
Acrylic rings made up for the mids
Glued into place to prevent audio leakage and installed back into the factory spots
Off with the doors and plastics
Sound deadening strategically applied to the inner and outer door skins
Custom fiberglass sub box being constructed in the boot well. Had to be removable without having to unscrew the driver for quick weight shedding
Layering up..
The pros use foil and wax as as base coat, new box pops out with no residue left behind
Building the base
And the new top fascia piece to be trimmed in factory carpet
Built strong enough to accommodate some load
Custom rings made up for the 6.5" door speakers and extra clearance depth
Mids going in
Dash speakers going in
All neatly tucked away
Well thats the fun part over with.. now gotta spend 200+ hrs breaking in the new drivers and endless tuning fun ive got with the DSP.
Will post up thoughts / reviews once Ive had a chance to listen to it all in a bit of depth, but so far so good
GaDgeT is offline   Reply With Quote
Old 06-11-2013, 07:53 AM   #2
ft_sjo
Drives: GT86
Interesting choice of kit; curious to see how those drivers perform in the stock locations with minimal reinforcement.
Old 06-11-2013, 10:24 AM   #3
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Looks good. I haven't heard any of the new Boston subs but I loved my Pro 10" that I was using around 2003-2004. Let us know how that PXA-H800 works out for you.
Skippman is offline   Reply With Quote
Old 06-14-2013, 01:38 AM   #4
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
I like the choice of car you bought with that stereo!
michaelahess is offline   Reply With Quote
Old 06-16-2013, 12:44 PM   #5
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
how does that imagine 6.5 sound with the SE 4 and L1 tweet?
Sbeezy is offline   Reply With Quote
Old 06-17-2013, 12:33 AM   #6
GaDgeT
GaDgeT's Avatar
So far it all sounds pretty epic.. had the processor hooked up to the lappy last night to do some tuning, time correction and eq'ing.. benefit of a 4 way active system is you manually set crossovers, levels, eq's and timing on each individual speaker and blend the sound across all drivers.
Heaps of tuning still required, but have SQ comp finals on next weekend, will see how she stacks up once the judges have had a listen
Old 06-17-2013, 04:58 AM   #7
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
I have a Boston g3 10 in my FRS lol. Such a good sub!
FRSfan111 is offline   Reply With Quote
Old 06-17-2013, 05:52 AM   #8
GaDgeT
GaDgeT's Avatar
yep, it certainly moves some air and rattles your bones ;p
Old 06-17-2013, 02:28 PM   #9
Sbeezy
Are you using a RTA or alpine's software to tune?
Sent from my SPH-L710 using Tapatalk 2
Old 06-17-2013, 09:29 PM   #10
GaDgeT
GaDgeT's Avatar
Using RTA to get the eq curve and Alpine sound manager software via laptop connected to DSP. Science and math can only get you so far, a well trained ear is still required to know what to do.
The RUX controller can do all tuning on the go, but have not mounted into center console or anywhere I would be tempted to play with it while driving.. hidden in the glove box for now
Old 06-18-2013, 12:20 AM   #11
Sbeezy
I agree a trained ear will help the most with system tuning.
Old 08-17-2013, 02:56 AM   #12
GaDgeT
GaDgeT's Avatar
Hey guys,
Few quick updates with the audio build.. Wasn't happy with the finish of the boot install, thought id build up something a bit lighter and more presentable
Started off by photoshopping a false floor with go loud bits on display
Then got to work building up a template.. used this method with playing cards and cardboard a few times, works a treat for a perfect cut and flush finish
Traced out template onto some plastic corrugated cardboard and cut away the square shapes with a Stanley knife and router for the circle
Installed hidden supports to raise the floor piece to be level, then glued a foam sheet to the top to hide any screw holes, corrugation and imperfections underneath
Now just gotta trim this up in vinyl and work on a protective top piece in factory carpet
Old 08-18-2013, 11:42 AM   #13
Skippman
Skippman's Avatar
Nicely done! Never seen the playing card trick before but it makes complete sense!
Old 08-18-2013, 02:05 PM   #14
wheelhaus
wheelhaus's Avatar
beautiful work! I bet it sounds epic... and I'm jealous lol
wheelhaus is offline   Reply With Quote
GaN-MaN's Custom Audio Setup + Sub/Amp Box GaN-MaN Electronics | Audio | NAV | Infotainment 23 03-26-2014 06:43 AM
Custom audio in the FRS Kwise1 Scion FR-S / Toyota 86 GT86 General Forum 1 11-12-2012 07:27 AM
Custom Start-Up Sound/Audio? joergasm Electronics | Audio | NAV | Infotainment 1 10-25-2012 04:54 PM
Custom Audio Shop LPC_FRS Mid-Atlantic 0 09-17-2012 08:42 PM
Custom Audio Shop LPC_FRS Mid-Atlantic 0 09-17-2012 07:11 PM
