Old 06-17-2013, 02:45 AM   #1
retrosmiths
Drives: Scion FR-S Whiteout
Popping sound
Bone stock FR-S, 2.6k miles in, just went for a long drive (600 miles back and forth). Haven't hit a pothole or anything, just your regular freeway roughness.
I hear a pop sound from the front-passenger side whenever accelerating or stopping quickly, sometimes also when changing lanes. It happens once, then it won't repeat until the next event above, so I don't think it's the tires. My guess is something rubbery from the suspension. Anyone else having the same issue?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 06-17-2013, 03:04 AM   #2
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Sounds like the infamous leaky injector.
Muaddib is offline   Reply With Quote
Old 06-17-2013, 03:05 AM   #3
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
My guess would be suspension of some sort.
What freeway were you driving on? 101, 110, 10 or 5? 10, 5, and 101 have really horrible road conditions from what i remember. I wouldn't rule out struts crapping out on you. How long have you had the car for?
I'd also double check the lugs or the cvboot (not sure if this car has issues with them) -- try turning the steering wheel and see if that pops anything out for you. *shrugs* just guessing based on what you said.
CamryDS is offline   Reply With Quote
Old 06-17-2013, 03:13 AM   #4
retrosmiths
Had it for about 2 months now. Driving on I-5 (LA to SF to LA). How could this be the injector?
2013 Scion FR-S
Old 06-17-2013, 03:19 AM   #5
Muaddib
Mentat
Muaddib's Avatar
Popping sound is from detonation that was causes by the improper ignition timing. Hopefully i am wrong otherwise your car will be out of commision for a while.
Old 06-17-2013, 03:20 AM   #6
retrosmiths
Even when braking??
2013 Scion FR-S
Old 06-17-2013, 03:22 AM   #7
mashal
DADA
mashal's Avatar
Drives: 2013
Originally Posted by retrosmiths View Post
Even when braking??
Engine has ignition all the time
mashal is offline   Reply With Quote
Old 06-17-2013, 03:26 AM   #8
retrosmiths
I meant it can be reproduced when braking hard suddenly, even without revving the engine and letting the car slide downhill.
2013 Scion FR-S
Old 06-17-2013, 03:32 AM   #9
heeltoe86
heeltoe86's Avatar
Drives: 2012 Ultramarine FR-S
Can you reproduce the popping noise by free revving the engine at idle? I had a missing injector seal and heard misfiring right away. You can search for my youtube video on here or of course youtube.
2013 Ultramarine FR-S daily/trackwhore
1986 Toyota AE86 (sold)
2007 Toyota FJ Cruiser (sold)
2006 Toyota Tacoma PreRunner (sold)
1996 Honda Civic (sold)
heeltoe86 is offline   Reply With Quote
Old 06-17-2013, 03:59 AM   #10
retrosmiths
It doesn't sound like the popping sound of the injector issue, and it doesn't seem to happen at idle (although I will have to double check this tomorrow).
Another issue that could be related (if this is about the injectors) is this: On 1st gear, with clutch pushed in and the car fully stopped, the revs seem to play up and down from 600 to 1,500 RPM. Is this normal?
2013 Scion FR-S
Old 06-17-2013, 09:02 AM   #11
rx3
Engine has ignition all the time.
But fuel is not injected when the car is above a certain rpm and the throttle is not touched (e.g. downhill engine braking).
In order to make a popping sound with a combustion process you need a spark, air (oxygen) AND fuel.
rx3 is offline   Reply With Quote
Old 06-17-2013, 09:53 AM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I was thinking all the way it had nothing to do with the DI leak, but the bolded part sold me. That is one of the symptoms.
Old 06-17-2013, 10:13 AM   #13
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
A leaky fuel injector would still leak fuel, as it would be damaged right? Thus the poping we hear when they're damage. I don't know if this applies to the OP here though.
Rayme is offline   Reply With Quote
Old 06-17-2013, 12:23 PM   #14
retrosmiths
Could you link me to more info about this symptom? :eek:
Sent from my Galaxy Nexus using Tapatalk 2
2013 Scion FR-S
Sway Bar Popping Sounds? fareastbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 03-28-2020 01:23 AM
Anyone heard any loud popping? Kimsey47 BRZ First-Gen (2012+) — General Topics 103 07-30-2013 10:27 PM
Light popping sound when I steer, even when parked. Jar Issues | Warranty | Recalls / TSB 2 06-01-2013 06:27 PM
GTS rear left popping/clicking sound and fix. sigmaoctantis AUSTRALIA 11 05-19-2013 07:58 AM
The number 86 popping up everywhere.. CSSM Off-Topic Lounge [WARNING: NO POLITICS] 19 06-19-2012 12:15 PM
