Old 06-17-2013, 05:40 PM   #1
echan
Drives: Triumph TR6
Next CDC Autox ($10 discount for 2nd slot) Sat 6/29/13 James Wood HS Winchester VA
Saturday June 29th Autocross
James Woods HS in Winchester, VA is the location of the next Capital Driving Club autocross on Saturday June 29th.
Registration and tech inspection will be at 8:15 (giving you 15 extra minutes) and will promptly close at 8:45 to try to accommodate the full field, while still giving 6 runs. You must be DONE by 8:45. So if you arrive at 8:15 you won't have a problem. Don't arrive at the last minute.
The event fee for the Saturday autocross is $30 for members and $40 for non-members.
On-line Reservation System
Member reservations (or participants that will join the club upon showing up) for any events can be made at any time. Open reservations for non-members for this event begin Friday June 21st.
New Members
We will be accepting new members at this event. If you plan to join the club at this event, you may make a reservation at this time by doing the following:
1. Use "0" as the member number (a permanent number will be assigned to you after you join and you will get a temporary number for this event)
2. TYPE "I will be joining the club at this event" in the NOTES section when making you reservation.
$10 Discount on Second Slot
To help increase interested in this event at James Wood HS in Winchester, VA, we are offering the following special.
For anyone paying for a second slot, the second slot will be $10 off. So if you are a member the second slot for a member will only be $20. If the second slot is for a non-member the cost will be $30 (rather than $40).
The second slot can also be used the same driver (e.g. they would drive in two heats) or for a guest.
If you sign up for a second slot, just type "Second Slot" in the Notes Section. Otherwise, we may think you mistakenly submitted duplicate reservations.
Remember, to make a second slot, MAKE A SECOND RESERVATION (if the second slot is for a different person, type "Second slot for (type the name of the first slot person)".
-Several people used the second slot for a guest (some that never autocrossed with CDC) -Many participants used the second slot to get 12 runs -Some used the second slot to be a point autocross in the 6 morning runs (since only the first 6 counted for points) then treated the afternoon as a TNT by trading cars with other two slot participants
This offer is only extended for this event at James Wood HS on Saturday June 29h, 2013 and will only be offered at James Wood HS.
If you have any questions, let me know at capitaldriving@yahoo.com.
Ed
echan is offline   Reply With Quote
Old 06-17-2013, 11:59 PM   #2
Sargy
Long Distance Driver
Sargy's Avatar
Jesus I need to do something lol.
Sargy is offline   Reply With Quote
Old 06-18-2013, 08:42 AM   #3
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
I'll be doing AI and SCCA that weekend so I'll miss this one. Good luck to anyone who goes!
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 06-18-2013, 09:05 AM   #4
leon78
leon78's Avatar
Drives: 13 Whiteout
Ill be going to this since were getting double runs again.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 06-18-2013, 09:17 AM   #5
DarkSunrise
DarkSunrise's Avatar
Damn, that's my sister's wedding date. Too much stuff going on this summer.
2022 BRZ Build
2013 FR-S Build
Old 06-19-2013, 08:40 AM   #6
UncleFester
Going to pass on this one. May hit up AI. I will definitely be at the SCCA event on Sunday.
UncleFester is offline   Reply With Quote
Next CDC Autox ($10 discount 2nd slot) SUNday 6/16/13 James Wood HS Winchester, VA echan Mid-Atlantic 19 06-18-2013 02:24 AM
Power Slot vs Stoptech drilled rotor JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 41 10-19-2012 01:04 PM
2nd Slot $10 Discount for Next CDC Autocross SATurday October 13th Bowie Baysox echan Mid-Atlantic 0 10-03-2012 07:52 PM
($10 Discount on 2nd slot) CDC Autox Sat Aug 11th Hylton HS Woodbirdge, Va echan Mid-Atlantic 0 08-09-2012 11:57 PM
Why I think James May will like the 86. Dadhawk Other Vehicles & General Automotive Discussions 10 05-09-2012 06:10 PM
