Old 06-20-2013, 04:05 AM   #1
BRAWL
Drives: Toyota 86 GTS Velocity Orange
Brakes from other vehicles?
I have a set of Brembo calipers from a Nissain Skyline R33 GTR. Would these be able to be adapted to fit the 86 or is it more hassle than it is worth?
I would like have to get a custom rotor for it, but I assume it could be done?
Can I get opinions and thoughts?
BRAWL is offline   Reply With Quote
Old 06-20-2013, 04:21 AM   #2
ft_sjo
Drives: GT86
Yes it can be done with custom fabrication. You may need a change of wheels though to accommodate.
Old 06-20-2013, 11:01 AM   #3
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
The piston bore sizes are likely not optimized for the proper brake bias/balance on the FT86. The items that can alter the bias are disc diameter, piston bore size, and brake pad coefficient of friction (mu). All of the below items assume that you don't want to change your brake master cylinder (which 98% of the people reading this likely have no desire to do).
If you held everything else constant on the car and just increased the front disc diameter, you'd shift brake bias towards the front of the car.
I don't know the piston area on the GT-R off the top of my head, but it is likely far larger than the piston area on the OEM FT86 calipers. That would further amplify the brake bias towards the front.
Now if you add a larger rear disc and larger rear caliper piston area, you can shift some bias back to the rear. That said, to be optimized for the BRZ, the front increase in brake torque and rear increase in brake torque would have to be in the same proportion to keep the overall balance the same as the OEM setup. That is possible, but highly unlikely.
The results of improper bias: All four tires are likely not sharing the proper amount of work. In most of these cases, the car is front biased, which means the rear tires aren't being used to their full capacity to stop the car...resulting in longer stopping distances than stock. Also, you run the risk of having ABS problems, or premature intervention. Finally, if the overall piston bores in the calipers are substantially larger than stock, you will be displacing a lot more brake fluid into those calipers. That can mean that your brake pedal travel will be longer.
In summary...upgrading to Brembo's from another platform such as an GT-R, STI, Evo, or 350Z would primarily be a cosmetic upgrade only. The brakes would look better, but that's about it. Your actual performance would likely be worse...and possibly be much worse. Longer stopping distances, longer pedal travel, potential ABS issues, pad taper because of the 'upside down' calipers, etc. So if you want your car to look good parked, putting OEM calipers from another application is a good solution. If you want it to have the best braking performance possible...not so much.
All of these factors need to be considered when you design an aftermarket brake system upgrade to work with the OEM master cylinder on your car. The proper disc size, piston bores, and piston stagger all need to be calculated to achieve proper brake bias and performance.
Hopefully that helps.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 06-20-2013, 12:20 PM   #4
BRAWL
Exactly the answer I was after! Thanks mate
I will just keep trying to sell them and not bother with Plan B
Old 06-21-2013, 02:47 AM   #5
troek
troek's Avatar
Drives: 2012 Toyota 86
man i saw this a day too late. my buddy just bought some r33 calipers for his r32. we could have done business.
Old 06-21-2013, 02:55 AM   #6
OrbitalEllipses
Drives: Attitude
What about swept area, Jeff? Does that alter bias or torque any?
Old 06-21-2013, 01:06 PM   #7
JRitt
JRitt's Avatar
No it does not. The distance from the center of the hub to where the center of the pistons squeeze the discs gives you your effective radius. If you hold piston size constant, the further from the hub center, the longer the lever arm = more brake torque. Swept area really only has to do with heat management. A larger swept area spreads the heat out more, but is just one factor in doing so. Other design features such as disc wall thickness, vane design, number of vanes, slot shape, pad volume, pad radial depth, piston material, airflow around caliper, etc. all impact how a system handles heat. In other words you can't just look at a setup and say, "that one is better because it has a greater swept area." That's just one small piece of the complete picture.
www.essexparts.com
Old 06-21-2013, 01:16 PM   #8
BRAWL
Story of my life I have them on ebay and have had them on SAU/aus300zx forums with only nibbles, partial interest and low ball offers. At this point, I am selling them for less than I paid
Old 06-21-2013, 04:46 PM   #9
ft_sjo
Drives: GT86
So we shouldn't put any bbk on the front at all jritt? Even your AP based kits? Not without changing the rear brakes too?
Old 06-21-2013, 04:53 PM   #10
wparsons
wparsons's Avatar
It depends on if the kit was designed to maintain the stock bias or not. Most BBK's will explicitly state if they work with stock rears or not.
flickr
Old 06-21-2013, 05:02 PM   #11
ft_sjo
Drives: GT86
Well the Brembo's i'm fitting to my car (which are very common on various vehicles) have the same piston sizes are typical AP calipers designed for a 50-51mm pad height.
Old 06-24-2013, 12:47 PM   #12
JRitt
JRitt's Avatar
That is incorrect. If a front big brake kit is designed properly to work with the OEM rears (which all of the kits we sell are), then it integrates seamlessly without issue. You just have to make sure whoever designed the BBK did their homework and selected the proper disc diameter and caliper piston combination. That's the key. Those two variables will determine how much torque output is on the front, which needs to match the OEM torque output.
For a simplified example: holding the rear brake setup constant and the brake pad coefficient of friction on the front constant... If you increase the front disc diameter, you decrease the overall front caliper piston area...the combination of those two needs to match the OEM brake torque output on the front of the car, which maintains proper front to rear brake bias. If you went with a larger dimeter disc vs. stock and kept piston area the same as OEM, you'd end up with more front torque/bias. If you kept the disc diameter the same as stock but went with larger piston area, you'd again have more front bias. Typically you would go with a larger diameter disc to increase system heat capacity, and then counteract the torque increase of doing so by reducing the piston area on the calipers being run on those discs.
If you added a larger diameter disc AND a caliper with larger piston area (which is the common scenario when adding OEM brakes from a different car...a GT-R in this case)...then you're getting a double whammy: more front brake torque because of the larger disc, and more brake torque because of the larger piston area. That shifts bias forward, your rears do less work, using less of your rear tires to stop the car, potentially increasing stopping distances, and/or problems with your ABS, a longer pedal because more fluid is displaced into the larger pistons, etc.
www.essexparts.com
Old 06-24-2013, 02:33 PM   #13
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
You would think. However, Subaru at least apparently doesn't feel that it's quite as big a deal. For example, the Legacy comes with two different sizes of front brakes (rotors are larger, caliper pistons are same size), depending upon engine/trim. However, the rear brakes are identical. And the master cylinder and booster part numbers are identical between the two setups as well.
Admiral Ballsy is offline   Reply With Quote
Old 06-24-2013, 03:17 PM   #14
ft_sjo
Drives: GT86
This statement has puzzled me a bit. Are you talking about area, or a ratio? If the only thing you've changed is the disc, then surely the caliper piston area is the same.
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 06:53 PM
TPMS and Canadian vehicles RoryTate CANADA 40 06-23-2013 09:39 PM
Scion 10 Series Vehicles xravexboix Dealer Cars 2 06-12-2013 09:48 PM
BRZ Demo vehicles for sale Redline_Randy AUSTRALIA 12 10-29-2012 10:28 AM
Natural Gas Vehicles and Sportscars KaliKev Other Vehicles & General Automotive Discussions 11 04-28-2012 07:16 PM
