Drives: really slow...
Yours for $249. These normally sell for $349.
These are the best matched lowering springs to the OEM dampers imho. They are also well matched to the Koni dampers as well. I'm including everything that came with the kit such as RCE custom bumpstops and the dust boot. • 20mm Drop FRONT and REAR • 250lb/in rate FRONT and REAR • Well-matched to OEM Shocks • Replacement bumpstops included ![]() Lowballers will be ignored but happy to take reasonable offers. If you are local to socal i'm willing to trade my OEM dampers already pre-assembled with these springs in exchange for your OEM dampers. Last edited by RYU; 06-25-2013 at 03:40 PM. |
Drives: '13 BRZ Ltd WRB
Oh man. I'm tempted! I work in San Clemente and a straight damper/spring swap would be perfect. If you still have these once I get some money in, I'm game.
'it's the yeti of Texas'
Drives: 2013 Whiteout 6MT FR-S
I was just curious Orb. I want to give RYU a fair offer.
BRZerhood & FR-Society
Drives: Attitude
#7 | |
Drives: Some rust bucket
#9 | |||
![]() Quote:
![]() Though, I have had springs break on my 1966 Chevelle but those were on 40yr old springs that's been sitting out in the farm somewhere before I bought it. I doubt these even have any knicks on them. I'm stupid careful and meticulous about installs. Quote:
#10 |
How much on top of trade are you looking for? Or straight swap? Cuz that I can do without hesitation!
#11 | |
Most guys don't have a spring compressor on-hand to uncompress the OEM spring. I'm passing thru Oceanside tomorrow morning and will be in Encinitas thru Saturday for some surfing! LMK if you want it. I can drop it off your way
#12 | |
Drives: 2013 FRS Ultramarine
FR-S Ultramarine: Berk Technology Dual Exit Muffler delete, all around tint, plasti dipped emblems/rims, ddm tuning HID 6000k kit
#13 | |
These springs are designed to be installed using the OEM damper. These springs are specifically designed for either the BRZ or the FRS damper rates. After uninstalling the OEM damper and spring unit from the car you have to uninstall/uncompress the OEM spring which can be a dangerous job if you do not know what you're doing. Once the OEM spring is removed from OEM damper using a spring compressor then you have to reverse the steps to compress the RCE spring onto the OEM damper again. It's a easy process if you have the right tools. It's outright dangerous if you do not. I'm simply offering a plug n' play option if the buyer wants my dampers already preassembled with the RCE springs on them in exchange for their OEM stuff. I'm assuming most buyers will have relatively low miles on their dampers (like I have) to where the mileage/wear won't really matter to me. I'm not sure how to describe it any better. If anyone cares to help describe.. please do. thanks!
#14 |
Drives: Attitude
Anyone local to you should just go for the direct swap of strut/spring assemblies. Less labor, less time, less hassle, and you only need an alignment at the end.
Compressing the springs requires a [ame="http://www.amazon.com/OEM-25550-Strut-Spring-Compressor/dp/B000CMDPLM"]$20-50 tool[/ame] and an impact gun (directions say no impact guns, but are you REALLY going to try and spin the compressor with a wrench? No you aren't, you lazy bum). It's easy...but it's not exactly fun and it's time consuming. Realistically an assembled set of struts should take less than 2 hours to do from removal to installation. Removing your assembly, disassembling it, removing his, disassembling it, then reassembling both, THEN bolting them to the car is a waste of time if he's offering his assembled struts. |
| Racecomp Engineering Tarmac Springs | forwallblakmail | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 03-25-2017 12:40 PM |
| Racecomp Engineering Yellow lowering springs install special! | Racecomp Engineering | Mid-Atlantic | 12 | 12-17-2015 02:34 PM |
| BRZ lowered on RaceComp Engineering springs! | OrbitalEllipses | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 03-19-2014 07:26 PM |
| Racecomp Engineering Yellow Springs and Cusco Lower Control Arm Review | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 07-28-2013 01:22 AM |
| Racecomp Engineering | industrial | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 05-02-2013 05:17 PM |
