Old 03-03-2012, 08:00 PM   #1
Canibuz
Canibuz's Avatar
Drives: BRZ SOON!
Stupid Question
Will push starting (rolling start) work with Push to start (ie Limited BRZ)? I will probably opt for the battery warmer. Sometimes in the north east it can get pretty cold and a battery will act dead, but once the temp goes up the battery will test perfectly fine. In my past cars I've only had to roll start once or twice a winter max. Just wondering if it is possible with this ignition system. I am guessing push start button once to get into ACC then roll start...??
The member of the BRZerhood formerly known as Reypt
How to spot a troll
Canibuz is offline   Reply With Quote
Old 03-03-2012, 08:11 PM   #2
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Hmm I would like to know this too.
I read this somewhere, "electronics have nothing to do with it, its the pump location. Yes, certain 60s cars will work."
Snoopyalien24 is offline   Reply With Quote
Old 03-03-2012, 08:43 PM   #3
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I don't see why not.
Just roll the car in neutral, jump in, clutch in, second gear, hold start button, clutch out then right back in again.
old greg is offline   Reply With Quote
Old 03-04-2012, 08:43 AM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If the car is "ON" it should start up.
Old 03-04-2012, 09:34 AM   #5
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I wouldn't count on a push start working. Newer cars are very dependent on the ECU to provide the right conditions to start. Also a battery that won't start the car in the cold is bad even if it tests good when warm. It's just a matter of time before it will start having problems all the time. This will be a new car, with a new battery, it should be at least a few years before you have to worry about any battey problems.
Old 03-04-2012, 11:15 AM   #6
WhiteGDB
WhiteGDB's Avatar
Drives: Civic Si sedan
This is a good question. Anyone with a proximity push start know how to get your car into the ON II position without starting your car? You know where you can operate your power windows, ac fan, etc.
Oh to the OP, welcome. Glad you decided to make a new thread that's worthwhile.
WhiteGDB is offline   Reply With Quote
Old 03-04-2012, 12:07 PM   #7
Snoopyalien24
Mr. Sarcasm
lol he was a prevous senior member who just changed his name...
Old 03-04-2012, 12:25 PM   #8
WhiteGDB
WhiteGDB's Avatar
Explains the lack of noobiness in his post.
Old 03-04-2012, 12:32 PM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
In Rhode Island?!? Synthetic oil alone would solve this, unless your battery is old then the obvious thing is to change it.
Old 03-04-2012, 12:33 PM   #10
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
In push-start cars I've used, it's basically like in any other car. Push the start button twice to get to "On", then push start the car, just like if you turned your key to "On" and then push started it.
I've done it in my Lexus, only to see if it worked. I can't imagine ever having to do this if everything in the car is right, I mean maybe once the car is old and crappy, but in a new(er) car? Doubtful.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 03-04-2012, 12:47 PM   #11
yayforaddison
yayforaddison's Avatar
Drives: Whiteout FR-S
If the battery is dead, you can't turn a push start button to "ON"
I honestly don't see this working. The electronics aren't going to come on just because your pushing it (the car itself), and let the clutch out in a car that can't be turned on without the electrical part (the push button). With a key, you actually have to leave the key switched to the "on" position. You can't do that if you can't "turn" the key to that position when it relies on battery juice.
Meh but then I think, as long as someone is inside holding the button down while you let the clutch out... Then maybeeeeeeee. But the car is probably thinking its "off" the whole time, because it won't let juice feed to the battery while its "off".
Im lost.
yayforaddison is offline   Reply With Quote
Old 03-04-2012, 12:50 PM   #12
yayforaddison
Jeff
You said you've done it in your Lexus, but your Lexus had a working battery. How are you going to push the button twice to get the switch "ON" if the battery were dead??
Old 03-04-2012, 12:57 PM   #13
neutron256
neutron256's Avatar
I think some people are confusing "Push-to-start" with "push starting" which is what the OP was asking about.
Old 03-04-2012, 01:07 PM   #14
WhiteGDB
WhiteGDB's Avatar
Looks like everyone is on the same page to me
Although I'm still trying to figure out this one:
Also yayforaddsion, a battery can have enough juice to power the accessories but not enough to start an engine.
Question jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 9 10-23-2020 12:31 PM
Question about the nomenclature.. RadOnc Scion FR-S / Toyota 86 GT86 General Forum 46 12-15-2013 12:55 AM
Combinations and Stupid Names quik1987 Scion FR-S / Toyota 86 GT86 General Forum 7 11-15-2011 09:15 PM
Stupid girl 2 foot driving GenkiElite Off-Topic Lounge [WARNING: NO POLITICS] 31 07-23-2011 09:33 PM
