Old 07-02-2013, 04:28 AM   #1
Fast_Freddy
Drives: Passat
Innovate questions
This appears to be the FI solution for me but based on it's initial launch dyno results I have questions and concerns.
First, dyno results show a very significant loss of hp and tq below 2600rpm on both Innovate's 91 octane and sw20kosh's WMI dyno results. Has anyone determined the cause of this?
Second, Innovate's dyno results look like their tune needs a lot of work still. Big hp/tq dip at 4500rpm and spiking that looks like possible knock correction.
Third, since several vendors are selling Innovate tuner kits with their own tune, where are the dyno results for those tunes?
Fast_Freddy is offline   Reply With Quote
Old 07-02-2013, 04:38 AM   #2
sw20kosh
Drives: 2013 Black FR-S
Any dip that you see on my dyno is not felt in the seat. A header will eliminate the remainder of that dip.
The kit was literally just released. Give tuner shops some time to produce the tunes/dyno graphs.
Old 07-02-2013, 04:59 AM   #3
Fast_Freddy
Drives: Passat
The 4500k dip is less pronounced on your dyno sheet but still there. IIRC the oem header dip occurs closer to 3500rpm. Does FI move it up the rpm scale? I could buy that.
The spiking on Innovate's dyno sheet is enough to cause concern. I suspect it's just a poor tune or maybe a 93 tune running 91 for the first time?
I'm probably just being impatient but I've already waited a year to buy this FRS due mostly to the pathetic oem tq and am anxious to make it into the car that should have been an option. I really didn't want a Genesis Coupe...
BTW, can you talk about who did your tune? I see that FA20Club, Moto-East, Rev-Works and Visconti are all offering Innovate stg 1 tunes but I'd like to know who has been involved in the kit development. TIA
Old 07-02-2013, 08:43 AM   #4
swift996
swift996's Avatar
I have the same dip N/A with headers FWIW, basically got rid of the stock dip but introduced a small one around 4.5k. I don't feel it like I did the stock one.
Ultimately there is no silver bullet. I chose to get the innovate kit because it fits my goals. I plan to tweak my setup (adding Water/Meth) and hoping to get ~260whp on 93 octane (w/ header, front pipe, and CAI intake).
If you're expecting 250 or so, I'm sure it will happen, but if you're thinking tuners are going to squeak out 300+, I think it's unlikely without a smaller pulley and E85.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-02-2013, 10:14 AM   #5
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
The kit has only been commercially available for a week. Expect to see independent tuning/dyno results in the next week or so.
The early adopters will flush this thing out in short order. I look forward to the Innovative & Vortech comparisons. Competition is awesome. In the end, we all win.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 07-02-2013, 11:05 AM   #6
jamesm
dyno's do a very, very bad job of representing how a car actually feels when you drive it, in general. if you're worried, wait til someone local gets one and take a ride before you buy. but in general, if you're wanting <300whp it's either innovate or vortech, >300whp you need to go turbo. that's really all there is to it. do you prefer a twin screw or centrifugal? if the answer is twin screw, <300whp, you've only got one option
as a side note, the 'stock' tune is irrelevant unless you're from the people's republic and need carb approval (which you can't get yet, anyway). the first thing you're going to want to do is get it tuned properly in any case.
Old 07-02-2013, 11:15 AM   #7
xxscaxx
Drives: 2013 SWP BRZ
1. I believe this was because the dyno operator did not start the run until after that. Someone correct me if i'm wrong.
2. Its hard to go by Innovate's posted dyno because that was a low end dyno, and they also are still refining the tune and trying to make it CARB compliant.
3. Like others stated, its too early at this time. Moto-East is doing dyno tuning next week.
xxscaxx is offline   Reply With Quote
Old 07-02-2013, 11:27 AM   #8
swift996
swift996's Avatar
The good news is there will probably be 4-5 new dynos posted in the next week or so.
Old 07-02-2013, 11:29 AM   #9
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Yes, you are correct. The pull was started later then the baseline. As is clearly shown in the graph.
Mentioned in a previous thread, it is not a super beefy pull. We are also still refining the tune. The graph in the other thread utilizes a version of the canned flash that is 3 generations old. The current version, is already significantly better and is much closer to what the canned flash CARB version of the system will actually get.
All true, several tuners have kits in hand and in the process of or will shortly be developing and releasing canned flashes for these systems.
mines13 is offline   Reply With Quote
Old 07-02-2013, 11:30 AM   #10
brillo
Drives: 2013 Firestorm FR-S
Their S/C is too new to pass any kinda judgement yet on performance. Let the tuners work out the tuning kinks before you decide. While I don't think the ultimate power will go up materially, I bet the average power and power band will get smoother and more refined, which is what you care about real world. I would check back in on the product in 3-6 months and I bet you'll be happy with what you see.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-02-2013, 02:13 PM   #11
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
We needed another innovate thread, thank you op for not searching.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 07-02-2013, 02:51 PM   #12
FeaR-S
Drives: Great White
Originally Posted by brillo View Post
Their S/C is too new to pass any kinda judgement yet on performance. Let the tuners work out the tuning kinks before you decide. .
FeaR-S is offline   Reply With Quote
Old 07-02-2013, 03:27 PM   #13
robispec
Drives: Black frs project
We will get to 300 dynojet...whp, I hope with the 65mm pulley
robispec is offline   Reply With Quote
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 11:25 PM
Innovate Stg1 Supercharger with W/M injection sw20kosh Forced Induction 180 09-23-2013 05:30 PM
innovate SC for sale kioton32 Forced Induction 4 04-08-2013 12:42 PM
FS: Innovate Motorsports OT-2 pixel67 Engine, Exhaust, Bolt-Ons 0 01-05-2013 11:13 AM
