Old 07-08-2013, 04:07 PM   #1
Oburn
Drives: 2013 Subaru BRZ
P0102, P0113, P2096 Engine code
The engine light came on recently and these are the 3 codes showing. I have a perrin Catback exhaust and Rev Works header on my car right now. The exhaust was put on 2 weeks before the header, no engine light.
I got the header installed, and the light was showing. Yes I had the 02 spacer added with it. The guys at the garage said it's possible the ecu may have to learn it and it may go away. Few hours later it did. 4 or 5 days later the light came back on, so I got it scanned and those were the codes.
I spoke to Matt from revworks, he said the p2096 code is from the header and it's possible it could be the spacer. I havent had a chance to bring the car back down to where I get it done because I work 14 days on and 7 off, just finished today.
The other 2 codes I don't really understand. They were going to instal the perrin cold air intake, they had the front bumper off, but the last 2 clips somewhere on the bumper they didn't take off until they called me because of the placement of them and they said it seemed like they were on a odd place and thought maybe there is some kind of trick too it, they didn't have time to go about it that day. So i told them to put the bumper back on and next time I bring it in to give Perrin a call see if their is a easy solution too it. So nothing on the intake was touched. But the first 2 codes seem to give a description of air flow and stuff so I have no idea whats going on.
Any imput or suggestions please let me know. Sorry for being so descriptive I just wanted to explain everything that went on so no details are left out and perhaps can help to narrow down the possibilities, thanks.
Oburn is offline   Reply With Quote
Old 07-08-2013, 04:20 PM   #2
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I just had the p2096 code as well. Check for an exhaust leak at the header to overpipe flange. Turns out my rev works header isn't properly fabricated to fit the stock over pipe flush, thus causing a massive exhaust leak. I had to replace the gasket and coat the top of the header to overpipe flanges in quiksteel high temperature exhaust repair. I just did this repair yesterday and so far it's holding up. I also reset the ecu and drove the car around a bunch and haven't gotten the code yet. Hope this helps
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 07-08-2013, 04:21 PM   #3
FR-S Matt
You need a tune. The ECU can't adjust on its own to the increased flow.
Old 07-08-2013, 04:25 PM   #4
CK_Bladesmith
Drives: Raven FR-S
Old 07-08-2013, 04:26 PM   #5
CK_Bladesmith
Drives: Raven FR-S
By the way you said you work 14-7? Sounds like you work in the oilfield like me, except we are 21-7.
Old 07-08-2013, 04:41 PM   #6
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
So was the flange warped on the header you received or are you saying that all Rev Works headers fabbed deliberately in such a way that causes massive leaks when mated to the stock overpipe?
If it was a warped flange then why aren't you using your 1 year warranty on the header and getting a new one?
Old 07-08-2013, 04:43 PM   #7
Oburn
Yeah I'm a pipe fitter I'm working in a new nickel processing plant, a lot of the mods that were sent down were built in Texas actually lol
Old 07-08-2013, 04:44 PM   #8
Oburn
So Matt until I get the tune is it safe to drive the car the way it is because I won't be able to get a tune until prob next month or so, or is it just having to deal with the engine light being on
Old 07-08-2013, 04:45 PM   #9
FR-S Matt
It just won't be running optimal. Might burn more gas and you'll lose MPG, but you can drive it. I just suggest not driving it for a very long period of time. I would be anal about those codes. You could swap the stock header back on in the meantime till you can grab a tune.
Old 07-08-2013, 05:18 PM   #10
Oburn
I'm not worried about the gas I don't drive enough for that because of work and I can't go back to the old header, I'm too addicted to the boxer sound now just love the roar of it at 4k Rpms and above
Old 07-08-2013, 05:33 PM   #11
CK_Bladesmith
Drives: Raven FR-S
Originally Posted by ATL BRZ View Post
So was the flange warped on the header you received or are you saying that all Rev Works headers fabbed deliberately in such a way that causes massive leaks when mated to the stock overpipe? If it's the latter then why would RW advertise their header as being compatible with the OEM headerback?
The flange is completely flat. It looks to me like the entire collector/flange area needs to be bent down maybe an eighth of an inch. I unbolted the header to overpipe flange and the overpipe to front pipe flange (perrin high flow catted front pipe), then completely took the front pipe off. I pulled the overpipe up and over a little to make it seat perfectly flush with the header and that threw the rest of the exhaust off. I'm not going the warranty route because its not worth the hassle of me having to wait a month for a new header. Quiksteel fixed it....it may not be pretty, but so far it's good. Plus it's heat resistant to 2400 degrees F. If it starts leaking again ill just patch it again.
Old 07-08-2013, 05:43 PM   #12
FR-S Matt
Long story short, the engine doesn't know the optimal amount of fuel to use because the sensor reading is off so it defaults to a regular set value in the ECU and goes with it, hence why it runs inefficiently and could damage the engine over time.
Old 07-08-2013, 08:59 PM   #13
Oburn
God damn no one told me any of this when I was asking questions about parts lol, people said it would be fine to go with a header and catback exhaust before getting a tune. Now my engine apparently might blow over time if I don't get a tune :/
Old 07-08-2013, 09:43 PM   #14
ATL BRZ
ATL BRZ's Avatar
This is incorrect. The primary O2 sensor is pre-cat and is the only one that effects fueling. Running a catless header on the stock ECU tune is a non-issue and will not throw a code if you use a long enough secondary O2
sensor spacer or mini-cat. The secondary O2 sensor is for detecting cat readiness and does not effect fueling.
Sure you are leaving power on the table with a header and stock tune but to say it's damaging the engine over time is not accurate.
See above
Another CEL code whitefrs Forced Induction 20 11-27-2019 12:27 PM
P0328 Engine Code Lil Abner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-23-2014 01:10 PM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 05:23 PM
check engine/CEL/DTC/MIL code list arghx7 Engine, Exhaust, Transmission 3 07-04-2012 11:37 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 06:06 PM
