Old 07-10-2013, 10:06 PM   #1
Mako
Drives: 2013 Scion FR-S Ultramarine 6-Speed
Exclamation Issue after battery disconnect Audio related.
So I recently installed a TRD CAI which had me disconnect the negative terminal for the battery during install. After install, I reconnected battery, started car and let it idle for about 5 minutes in order for the ECU to start relearning. It's been one day after install. I've noticed a throttle dead spot that I'm hoping will go away as i continue to drive and the ECU relearns everything. As far as the audio issue: I sit a light I turn up the music, after re-setting my audio settings, and the bass sounds normal. As I start accelerating with the windows down it sounds as if the bass drops and sounds like my speakers are blown. I come back to a stop at another light and the bass come back to normal. I'm wondering if I blew a fuse as when I reconnected the negative terminal there was a little spark. I don't know what to go next.. Need advice please.
Mako is offline   Reply With Quote
Old 07-10-2013, 10:14 PM   #2
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Have you set it back to FR-S instead of tC?
After disconnecting the battery, it sets itself back to tC.
Sigh-on-Rice is offline   Reply With Quote
Old 07-10-2013, 10:18 PM   #3
Mako
Not sure if trolling or if serious. If you're serious I don't know what you mean.
Old 07-10-2013, 10:27 PM   #4
Sigh-on-Rice
Ok, that means your audio is in tC mode.
It's stickied in audio section.
http://www.ft86club.com/forums/showthread.php?t=7578
Old 07-10-2013, 10:29 PM   #5
Mako
Found it lol! Ya it was in tC mode lol thanks a lot!
audio, battery, battery disconnect, issues, trd cai
Disconnect battery for all LED installation? husker741 Cosmetic Modification (Interior/Exterior/Lighting) 3 03-30-2013 04:25 PM
BRZ Audio Unit - Flash Drive (USB) & indexing issue Space Boy Matt Electronics | Audio | NAV | Infotainment 3 12-08-2012 11:29 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
BRZ Stock Audio Video System / USB Drive Issue Space Boy Matt Electronics | Audio | NAV | Infotainment 0 10-23-2012 02:19 PM
Winter battery disconnect Skye Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-23-2012 01:28 AM
