Old 07-13-2013, 07:28 PM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
squeaky window due to window rubbing against rubber at the top
my windows have been squeaking when i close the doors (and the window advances up to get the seal). turns out it's from the window rubbing against the rubber gasket(?) along the top. is there a product that i can condition this rubber area with without getting the product onto the window itself?
tracerit is offline   Reply With Quote
Old 07-13-2013, 07:46 PM   #2
5th 86
Drives: 2013 BRZ SPORT TECH
Most rubber seals are good with silicon lube, just spray on cloth and wipe.
5th 86 is offline   Reply With Quote
Old 08-10-2013, 01:53 AM   #3
jermyzy
Drives: 2013 WRB BRZ Sport-Tech 6MT
Just had it happen today myself. It only happens when rolling window down, and past 75% mark. Never happened before today...but...it's a LOUD squeal. Now I've noticed faint scratches on the window too!!! Is it worth bringing to dealership to get looked at or will using silicon lube do the trick?
jermyzy is offline   Reply With Quote
Old 08-10-2013, 03:56 AM   #4
thientai
thientai's Avatar
Drives: Firestorm Scion FR-S
Not sure if this is the same issue but sometimes, when I roll the window down, I hear a loud screeching noise, almost like a chalk board being scratched.
This isn't the same noise I described but here's what I was able to record. The really loud screeching noise turned into that in the video.
[ame="http://www.youtube.com/watch?v=HdOlZTwtu8M"]FRS Window Squeak - YouTube[/ame]
thientai is offline   Reply With Quote
Old 08-10-2013, 04:35 AM   #5
tracerit
That's what happens to my windows too. When the Window touches the top seal. Doesn't happen after I clean my windows though. Weird.
Old 08-10-2013, 06:34 AM   #6
OrbitalEllipses
Drives: Attitude
Think about it...lubricating effect of whatever you're using is reducing the friction such that there's no noise. The product wears down and boom, you have noise again.
OEM parts? Burned rubber door/window sill l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 04-08-2017 08:32 PM
window sounds like its rubbing jybrd Issues | Warranty | Recalls / TSB 9 07-10-2013 06:45 PM
Small window door issue (rubber seal) Subforever Issues | Warranty | Recalls / TSB 7 05-20-2013 06:32 AM
Window rubber crack after 1 month motofan Issues | Warranty | Recalls / TSB 16 09-28-2012 10:34 PM
Pop out window brett_g Cosmetic Modification (Interior/Exterior/Lighting) 10 07-22-2012 11:42 AM
