Drives: 2013 DGM BRZ
Wider wheels: need an alignment?
Car is being dropped on eibach sport line springs very soon. I know I need an alignment after the drop but this is my question:
I'm upgrading to a set of 17x9 +44 wheels. Tires will be stock. I want to know if I shoul hold off on the spring and alignment until I get the new rims on or will a wider wheel not effect the alignment/handling of the car? Any advice is appreciated. Not in a hurry to do the springs if it will benifit to wait |
#2 | |
Proud of BOXER
Drives: Subaru Boxer
You're putting 215s on 17x9s? That's probably going to affect your handling more than not having an alignment right away.
we recommend any drop or even wheel and tire change to have alignment done. Remember that you are altering the suspension geometry with any of those changes.
How exactly are you altering the suspension geometry (specifically the parts affected by an alignment) by changing wheels or tires?
The ONLY thing that can change with a wheel change is the offset, but that's not something you can change with an alignment so it's irrelevant.
#5 | |
#6 | |
Out of curiosity, what alignment specs would you set my car to running 225/45/17's on 17x8 +45, and why would you deviate from the factory alignment? I fully realize that the factory alignment specs aren't the fastest specs around a track, but that doesn't mean you need to adjust based on wheel offset. If you're that concerned about on track performance you need to factor in a lot more data than just width and offset, actual logged data like tire temps across the width of the tire, pressure, etc all come into play. None of that matters for the average street driver though. The only other time I can see this mattering is if you're setting camber for fender clearance, then you would need the final wheels to get the clearance right. To answer the OP's question, just get the alignment after the suspension install, changing wheels won't change the alignment at all. A good number of alignment racks require removing the wheels anyway.
#7 | |
Its like hub rings, there are people out there who says its not needed... but from a manufacturers side, we recommend them because it is just one less factor to contend with in case there are shaking or vibrations on the car... that being said, as a wheel manufacturer, we always would recommend alignment after wheels and tires are put on to protect the consumer. |
#8 | |
Better yet, how are you validating the "handling differences" between wheels? The alignment specs are numbers that are going to be identical whether you're on stock wheels or these. So, what, you're going to put a new set of wheels on a car, put it on the rack, verify that the tie rods haven't been touched, pocket $90 and call it a day?
#10 |
So what I'm gathering is that the wheels may affect my handling characteristics but not due to alignment. I think I'll get it aligned w the stock wheels then just put my new ones on. Once I wear through the tires I'll get another alignment as I'll be putting wider rubber on. (215 on a 9" rim is about as stretched as I'd ever want, definitely not about the stance scene.) I appreciate the insight and would like to continue learning more. So any other voices are more than welcome
#11 |
Drives: BRZ Limited, WRB, 6 MT
Don't the 17x9's hit the tie rods at full lock?
#12 |
#13 | |
As to others thinking its ok not to align the vehicle after changing even just tires, thats their choice. In our experience, we have fitted on slightly wider tires and slightly bigger tires on stock suspension set up without alignment to compensate after. The results were uneven wear on the tires. |
#14 |
As to those implying there is ANY different to your alignment after changing wheels or tires.. I don't even know what to say. There isn't. Period. To suggest it's even possible is crazy. Do you readjust your belt when you put on a different pair of shoes?
| What would make the rear tires look wider?? | Razor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 02-19-2013 12:16 AM |
| Question for everyone who has gone 8.25" and wider | SkAsphalt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-05-2012 04:46 PM |
| Better to go wider or lighter? | BRAWL | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 08-02-2012 10:48 PM |
| Factory Replica BRZ Wheels, but wider? | boarder1995 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 06-18-2012 08:32 PM |
| Looks wider than it is | Sigh-on-Rice | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-11-2012 09:15 PM |
