Old 07-18-2013, 02:31 AM   #1
husker741
Thump happened on downshift into 2nd
Alright so this has happened three times now. I rev match downshift to second, and I hear and feel a thump/pop and the revs go down while the engine bogs. Is this the DI failure? Or is this a totally different issue?
husker741 is offline   Reply With Quote
Old 07-18-2013, 03:13 AM   #2
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
don't walk , run to your nearest dealership and have it looked at. better safe than sorry.
good luck
"Power is nothing without Control"
j2digit is offline   Reply With Quote
Old 07-18-2013, 12:22 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
When does the thump/pop occur? When you still have the clutch in and you move the gear shifter from 3rd to 2nd or after that when you let the clutch back out? Are you using the clutch to downshift or relying on rev matching only?
Old 07-18-2013, 12:57 PM   #4
husker741
At about 3k rpm while I have the clutch in and revving the engine to downshift. I am using the clutch.
I'm sick of taking it to the dealer because if they can't replicate it, then they won't fix shit. It's only happened three times so getting it to do it again won't be easy.
Old 07-18-2013, 01:03 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
So the physical act of moving the shifter from third to shift is when the noise occurs then. Does it seem to be RPM dependent? Like if you don't rev match, or get your rev match too high, does the noise not occur. If it very rarely occurs, I would not worry about it.
Old 07-18-2013, 06:51 PM   #6
Carwhisperer
Drives: A lot of supercars.
Its it like a muffled pop from under the vehicle @husker741 I rarely have gotten it to happen with a 3rd to 2nd "perfect" downshift at around 35-40mph.
Carwhisperer is offline   Reply With Quote
Old 07-18-2013, 10:19 PM   #7
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
I mentioned this in a another thread. Granted this is pure speculation, but I get this once n awhile. It does not sound like a misfire (DI issue) but it almost sounds like the clutch puck is sticking then slapping as if it were stuck. There is no jerk, it is a clean shift, but that is what it sounds like to me. I get it once n awhile as well, cannot replicate it, happens in 2-3 upshift mostly, 1 downshift note. Granted, 2nd gear in the car is VERY notchy.
Old 07-18-2013, 10:21 PM   #8
husker741
Do you guys that have it also have the grind into 4th and 5th at high rpms?
Old 07-18-2013, 10:26 PM   #9
Khazzy
Khazzy's Avatar
no grind for me. Just a real notchy 2nd and 6th. When we gonna get a 86 meet going there Husker?
Old 07-18-2013, 11:15 PM   #10
radroach
Drives: car
I also would like a solution for the notchy feel of the shifts. Bigger, softer bushings perhaps?
Saying this because I tested a mazdaspeed 3's shifter feel and it was much more plush going between gears.
Old 07-19-2013, 12:16 AM   #11
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Swap the fluid, it will help, but these transmissions are notorious for being notchy.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 07-19-2013, 01:07 AM   #12
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
I read somewhere on these forums that the shift is designed that way to perform better once warmed up (optimised for performance), so it will be notchy cold.
blue cat is offline   Reply With Quote
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 11:00 AM
AT - Failed to downshift in manual mode abutterman Issues | Warranty | Recalls / TSB 26 03-14-2013 10:11 AM
Thump sound after shifting.. Any ideas? imravenit Engine, Exhaust, Transmission 22 12-13-2012 08:24 AM
Occasional drivetrain thump when putting into 1st gear chaotichoax Engine, Exhaust, Transmission 5 10-21-2012 02:30 PM
transmission noise (when going to downshift) Hotlava86 Issues | Warranty | Recalls / TSB 5 09-03-2012 11:04 PM
