Old 07-21-2013, 07:48 PM   #1
brianhj
Drives: 2017 Camaro 1SS
Automatic?
I might be getting an FR-S automatic. I know auto is lame but bear with me.
I'm coming from a 2008 Altima 2.5S automatic. I want something with a bit more power. I'm looking at a 370z because I want to move to a coupe. However, I'm not a huge fan of its looks. I LOVE *everything* about the FR-S more than the 370z except the low power. So I'm hoping there's some way around that without having to worry about breaking anything.
Since I want an automatic FR-S I want to know what my options are to increase performance. Is it worth trying to get more power out of an automatic FR-S?
brianhj is offline   Reply With Quote
Old 07-21-2013, 07:50 PM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
There are a few people here with boosted automatics
86_ZN6 is offline   Reply With Quote
Old 07-21-2013, 08:27 PM   #3
Opposed
Drives: 2013 Asphalt FR-S
[ame="http://www.youtube.com/watch?v=nDkZ1Xyp8GI"]Full Blown Motorsports :: Subaru BRZ :: Stage 1 Base kit - YouTube[/ame]
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 07-21-2013, 08:41 PM   #4
brianhj
I saw that... just wasn't sure how reliable it was. I guess it boils down to me being afraid that I'll blow up a brand new car.
Old 07-21-2013, 08:55 PM   #5
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
If you want to make your future FRS faster than you better wait a couple years to turbo or whatever you want. In the time being, maybe add exhaust, intake, and all of the little things first so the car can still be reliable.
Kelbyat07 is offline   Reply With Quote
Old 07-21-2013, 08:56 PM   #6
brianhj
Does doing things like this invalidate the warranty? Also, is this kind of boost noticeable when doing daily things like entering a freeway, taking off from a full stop, etc..
Also what's the deal with e85? Will I need to use that gas now?
Old 07-21-2013, 08:58 PM   #7
brianhj
You mean buy it and then wait so that reliability is fully tested? That's a good idea actually
Old 07-21-2013, 09:08 PM   #8
Opposed
Any aftermarket force inducted kit will void warranty. That will have to be your choice. Im pretty confident that a mild bump in power such as a small turbo kit (FB, AVO, FA20club) or supercharger (Innovate, Vortech) 230-300whp should be plenty reliable. No, you will not have to run E85 unless you want to make more than 350whp. Power delivery will depend on what kit you end up going with. Most mild kits will give the feeling of having a larger V6 under the hood.
Old 07-21-2013, 09:22 PM   #9
brianhj
Good info! Like I said, I'm a newbie. So all this info still applies to AT? I saw someone in a thread say something about "gotta be brave to put a turbo on an AT." Don't know what he meant. That's when I thought I'm in over my head and I should just go with a car that's faster stock.
Any preference in regards to brand? AB, AVO, FA20club? If I purchase one online, any tuner shop can install it? They will do the tuning as well? I don't know shit about this stuff.
What's it like to drive on these turbo kits? If I'm not going to be going over 70mph at any time will it be worth it? I don't do any track driving or anything. It's going to be my DD.
Old 07-21-2013, 09:33 PM   #10
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
If i'm correct, the Auto is rated up to 400HP, can it handle 400HP for a long time? Well, only time will tell.
The automatic is basically the same auto from the Lexus IS-F, minus the two gears.
Old 07-21-2013, 09:55 PM   #11
Opposed
Most of the kits on this forum are all good quality kits. I might be a little biased towards FullBlown because they are a few miles from my house, and I know them personally. They are very nice, talented people. However, in your case, I would almost go with a supercharger. That is what I plan on doing. I have been following this kit from Innovate, which is fairly inexpensive ($3600 for the whole kit and tune) and very easy to install. Its also very limited in parts which could make it very reliable for long term daily driving use. http://www.innovatemotorsports.com/p...harger-frs.php Turbo kits are more labor intensive, and have more parts, piping and increase the underhood temps quite a bit. I don't want to turn this into a supercharger vs. turbo debate, this is just my opinion from experience. The driving experience will be the same, just more power! I don' know how else to put it. The supercharger route will be the best if you plan on never going over 70. It will greatly increase the low end torque for taking off and good midrange power. I suggest doing lots of research about force induction before you spend the money.
Old 07-21-2013, 10:33 PM   #12
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
That or just add little things to you car at a time. There is no rush.
Old 07-21-2013, 10:43 PM   #13
brianhj
Do superchargers have that whine noise? Yeah I saw that innovate supercharger, looks awesome. Man I'm more torn now than ever. Do superchargers and turbos pass inspection?? See, I want it to be as little maintenance and hassle as possible, but still have a significant boost. I can add oil to a supercharger but that's about as far as I'll go (besides the normal air filter, belt change, oil change of every car)
Old 07-21-2013, 11:26 PM   #14
jonbonazza
Superchargers have whine, turbos have vent. a supercharger is less power, but it isn't lost when shifting gears or letting off the gas. turbos generally make more power, but suffer form what is known as turbo lag when shifting and letting off the gas, where the built up pressure is vented to the atmostphere via a blowoff valve (which in turns generats the iconic "PSHHH" sound) Once ventilation occurs, you'll need to build boost back up from scratch. Turbos are greate for higher RPM power, while superchargers are more favorable for people looking for low to mid RPM power. SCs still make power up top too, just generally not as much as turbos.
EDIT: Turbos do have a spool sound, but it is distinct from a supercharger's whine.
jonbonazza is offline   Reply With Quote
Do you think FT-86 will have automatic? TRD Engine, Exhaust, Transmission 217 08-03-2013 10:36 AM
break-in for the automatic brz/frs chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 03-08-2013 01:52 PM
Red Automatic FRS available BRZ88 NY / NJ / CT / PA 0 06-01-2012 01:04 PM
My Car is here DGM Limited Automatic SgtBolt BRZ First-Gen (2012+) — General Topics 2 05-28-2012 06:03 PM
Anyone Else Considering an Automatic FR-S? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 410 02-16-2012 01:41 PM
