Old 03-16-2012, 04:37 AM   #1
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
Aftermarket gauge placement
Where do you guys say is a good place in the interior to put aftermarket gauges?
The TRD 86 has them where the radio is. But I don't think some of us will take the radio out just to put gauges in.
CyberFormula is offline   Reply With Quote
Old 03-16-2012, 05:30 AM   #2
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
one of my sponsors is actually going to make a 3 gauge pod....just have to wait till he gets ahold of one so he could start working on it...
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 03-16-2012, 09:57 AM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i'd prefer gauges to be as inconspicuous as possible
I like the ones that kind of blend in with the center console vents
Old 03-16-2012, 03:01 PM   #4
CyberFormula
^ me too dude
A pillar column pods look weird most of the time.
And this car doesn't have room down by the console (below the air cond. switches) for a clean look.
Steering wheel column pods look cheap.
I think the only way to get the best look is to get rid of the radio and buy an aftermarket headunit. But even then it doesn't look that clean as compared to JUST 3 gauges without the headunit.
Old 03-16-2012, 03:40 PM   #5
serialk11r
Drives: '06 AM V8V Coupe
Hmm I had this idea, either take out the radio or adapt the screen for use with a smartphone/tablet, and have your phone connect to the OBDII via bluetooth, and it'll be able to display a bunch of these parameters
Not sure if OBDII has oil pressure though.
Old 03-16-2012, 04:05 PM   #6
SkullWorks
Drives: SSM LT MT BRZ
ARK MFD gauge located in the cluster so the top right corner aligns (and covers) the digital speedo it should fit without crowding the temp and gas needles
SkullWorks is offline   Reply With Quote
Old 03-16-2012, 05:19 PM   #7
CyberFormula
i'm not sure the MFD has a peak/warning function...
Old 03-16-2012, 05:29 PM   #8
In theory at least, it might be possible to do this with the BeSpoke. It is bluetooth and you can develop apps for it. Basically, turn the BeSpoke into a MFD that shows the readouts as gauges. This is pretty common in glass ****pits in aircraft.
Old 03-16-2012, 05:36 PM   #9
SkullWorks
http://www.arkdesign-us.com/products...-function-dash
it wouldn't be good for much if it didn't have peak and warning function, a quick search netted this...you don't even need to read the text the pictures will make it pretty clear...
Old 03-16-2012, 05:43 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd prefer a placement similar to my current setup, which are molded into the gauge cluster bezel, not in mounted pods or on the steering column:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-16-2012, 06:50 PM   #11
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Nice! I'll take one....what will you charge me.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 03-17-2012, 04:03 PM   #12
koyv90
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
i wouldn't mind a gauge pod as long as it blended in well.
The best solution could be to just get a carputer, i believe some of them can actually show you stats?
koyv90 is offline   Reply With Quote
Old 03-17-2012, 04:19 PM   #13
Turbowned
Turbowned's Avatar
I wonder if it can be built into the nav screen... that would be the best placement
Old 03-17-2012, 04:22 PM   #14
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Yeah like have "app" looking thing where it shows everything a la GT-R R35 to name an example
Snoopyalien24 is offline   Reply With Quote
Aftermarket battery speed-wiz Scion FR-S / Toyota 86 GT86 General Forum 59 08-08-2012 12:23 AM
BRZ Aftermarket Sources brzmaybe BRZ First-Gen (2012+) — General Topics 50 01-02-2012 10:57 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
Aftermarket wheels? Levi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-06-2011 08:19 AM
