Old 07-23-2013, 07:05 PM   #1
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
Question Why the ecu make my tune run richer over time ?
I would like to understand why my ecu change my afr ratio over time?
Tony have set my afr to be between 12.5 and 13.5 at wot.
When I reflash with ecutek my afr come back to what it is suppose to.
If I do a log 2 or 3 weeks later I have a flat afr reading of 12.17 all the way until redline.
I do multiples logs and always have the same 12.17 reading.
If I reflash my afr ratio ( graphic ) come back to normal.
Does that means my tune is worth nothing ?
We worked hard to set the car somewhere and it look like the ecu is not keeping the AFR where we would like to.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 07-23-2013, 09:06 PM   #2
FA20Club.com
Drives: 2013 White Out FR-S
Sounds like your iam is dropping based on passive driving habits. You're probably somewhere around .5. Those who drive more aggressively have higher iam values weeks down the line. Mine stays around .7-.8. Its normal for NA suby to hover around .5
FA20Club.com is offline   Reply With Quote
Old 07-23-2013, 09:08 PM   #3
jamesm
What does that mean, exactly? If you don't drive hard, you're tune I learns it's way around itself?
Old 07-23-2013, 09:21 PM   #4
FA20Club.com
well basically in simpliest terms: when you flash the ecu the iam value is reset to its highest point. it will stay there for a bit but drops over time. the iam is total 1:1 ratio of the advance table. so when the iam is 1 you get 100% of ignition adv table. so if it drops to .5 you lost 50%. so if you ign adv was 5 degrees you just dropped to 2.5 degrees. which will see more unburnt fuel leave through the exhaust. so there are two ways to do it. run more timing on the base table which wont allow the ecu to pull as much timing when knock occurs or wait for the iam to drop and adjust the turn accordingly. i prefer the latter. this way you ecu can work as designed when it comes to its original ignition protocol. this is why i review logs over a extended period of time though time consuming creates a better all around tune to each specific vehicle and driver.
Old 07-23-2013, 09:46 PM   #5
mad_sb
Drives: 2013 Asphalt FR-S
Because your stacking up a long term positive fuel trim. More info here
Old 07-23-2013, 09:59 PM   #6
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
the 370z does the same thing, even with a reflash
the harder you drive the more power it makes..... to a point.
clayrush is offline   Reply With Quote
Old 07-23-2013, 10:22 PM   #7
number1Tango
Drives: Silver FRS
from what ive heard not just form this vehicle but other as well, even when you reflash your ecu and get more power, over a given period of time it will start reverting back to how it used to be with the factory AFR. I could be wrong, its just what ive heard.
number1Tango is offline   Reply With Quote
Old 07-23-2013, 10:25 PM   #8
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Read your writeup on this a while back mad_sb. Muchly appreciated, though a bit over my head. Beyond zeroing this out, is the only solution for those without editing abilities to just continue resetting? I know many people with a jeckyl/hyde complex with this car. Babying it around hyper miling it, and then beating the daylights out of it. Many have talked about how it feels sluggish after a few weeks of playing commuter.
Nightbringer is offline   Reply With Quote
Old 07-23-2013, 11:33 PM   #9
NoFear99
NoFear99's Avatar
My advance multiplier was playing around .88 and .90 today when i was loging so it was pretty close to 1.
The first picture is the AFR wanted that I got after my last etune reflash on june 26th.
Second and third picture is my afr on july 23th.
I did change the overpipe on july 22th but my afr was already showing 12.17 just before the install. So the overpipe is not the reason why my afr changed that much alone by itself.
If I do a reflash with my last etune I got in june, I bet 100$ my afr will come back to normal where it should be.
Old 07-23-2013, 11:50 PM   #10
FA20Club.com
why dont you send me the log since you just installed the over pipe and i was expecting your log anyway
Old 07-24-2013, 12:09 AM   #11
07jazzrs5gt86
Drives: Firestorm 86
So is this issue only on ecutek or does unichip also have this issue?
07jazzrs5gt86 is offline   Reply With Quote
Old 07-24-2013, 12:16 AM   #12
FA20Club.com
wouldnt consider it an issue since we have all been able to tune around them thats the difference between ecutek and unichip we have access to hundreds of tables to get everything working cohesively
Old 07-24-2013, 12:34 AM   #13
Fast_Freddy
Drives: Passat
^This.
Fast_Freddy is offline   Reply With Quote
Old 07-24-2013, 12:40 AM   #14
NoFear99
NoFear99's Avatar
Originally Posted by Fast_Freddy View Post
^This.
This thread you are refering me seem very interesting but too complicated for me especially when English is not your language.
May be somebody could explain here what this thread is all about in a simple short summary...
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
Just want to make sure Moonbase Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-16-2013 05:02 PM
Need to make time this weekend.. Khánh Scion FR-S / Toyota 86 GT86 General Forum 0 02-06-2013 08:43 PM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 10:53 AM
Time to make some noise and some demands: VR + AP CF FR-S/BRZ aero trim poormans_LFA Cosmetic Modification (Interior/Exterior/Lighting) 14 09-05-2012 05:44 PM
