Drives: 86
Engine Rev Limit
So i noticed my 86 wont rev over 7500. is this because computer limit? my 86 is MT and stock. any track pros out there know whats happening? thanks
Drives: 2003 Subaru Outback
Your engine not blowing up is whats happening.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Drives: Viper, Mustang, FD RX7, FFR GTM
Yeah. Its there so you don't over-rev and blow up your engine. Isn't that what is going on or am I missing something?
#5 | |
Drives: Passat
Because compromise ®
Drives: Red Herring
You can always try changing down to 2nd gear at 100mph let the clutch out and see how many rpm you can reach before disintegration.
is better than you
Drives: 2013 raven FRS
Dismember
Drives: 2013 Red Scion FR-S
They're basically rudely telling you that the rev limit is there for a reason. It keeps the engine from breaking. It's possible for a custom tune to raise the limit, but if it goes much higher, you'll have big problems. It'll probably take at least a tune and new springs to go to a higher rev limit consistently. Then maybe you'll need some water pump mods too.
Drives: FRS
I tuned and got up to 8,000 rpm but I wouldn't go
Higher lol |
#10 | |
Drives: 2013 Asphalt FR-S
No point in even getting close to the limiter in stock form since power falls off well before.
~Namaste~ Last edited by mad_sb; 07-27-2013 at 08:50 PM. Reason: to remove my ****ish coments, failed attempt at humor. |
#11 | |
With the torque dip you have to keep the car above 5k. If you shift at max power ~7k then you are only working with a 2krpm band. The gears aren't short enough. I and many others think the way to drive this car is to keep it over 5k and "bounce" the rev limiter or ideally just before it obviously. Maybe that's why my DI seals are shot but the car has a 7400rpm rev limit to be used, just because power is dropping after 7k doesn't mean you don't rev past there. Just my opinion.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#12 |
It doesn't matter if it makes less power after 7k rpm, when you factor in the torque multiplication from the gear you're in it will ALWAYS put more power to the wheels at 7400 (or even 8500) rpm than it will in the next gear after you shift.
#13 |
Drives: FR-S 6MT
Is this for real..? Get a clue people..
#14 |
Drives: Subaru BRZ Limited M/T
Just turn it off.
| How does BRZ handle at the limit in the rain? | tez2013 | Tracking / Autocross / HPDE / Drifting | 24 | 07-18-2013 03:22 AM |
| No Limit Motorsport | LeeMaster | User/Vendor/Sponsor Reviews, Feedback, Comments | 6 | 05-17-2013 01:16 AM |
| Rev Limit | Acid18 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 01-13-2013 05:55 PM |
| Pushing a tank of gas to the limit. | RoryTate | CANADA | 36 | 09-09-2012 11:22 PM |
| Dealer Limit | blackfireball5 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 06-29-2012 10:25 PM |
