Old 08-02-2013, 09:42 AM   #1
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
LED daytime running lights on when headlights on?
I'm looking for a DIY on how to wire up the daytime running lights to be on with all the selected option (no lights, Auto, parking lights, headlights) I noticed they go off with headlight use. Any threads out there yet on this topic? :happy0180:
DrDuquette is offline   Reply With Quote
Old 08-02-2013, 10:33 AM   #2
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
dont quote me on any of this, im just brainstorming...
but i dont think simple wiring would be able to do what you want. I would guess an inverter would probably be what is needed.
Because you want them on all the time yet they still need the capability to switch to high beams when you want them to. The way the DRL relay is set up is to shut off your DRLs when the headlights come on. So if you are good with that stuff you may be able to tinker around with the DRL relay wires.
FR-Shadow is offline   Reply With Quote
Old 08-07-2013, 08:52 PM   #3
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
if you dont care about high beam function you can do this.
this is hid powerhouse's G's high intensity super white DRL led's. they can be turned on as a highbeam, but dont function as a highbeam since they dont put out bright enough light(they wont blind other drivers). they do however put out a good amount of light compared to the factory DRL.
here is some photos showing light output.
headlights only(these are hella optilux xtreme yellow bulbs):
LED DRL/highbeam only:
headlights with LED DRL/highbeam:
hope this helps, i know its not rewireing but it achieves your goal.
WHITE is offline   Reply With Quote
LED daytime running lights sav AFRICA 168 03-22-2016 05:26 AM
Just installed LED Daytime Running Lights ... PHOTOS! F-T Cosmetic Modification (Interior/Exterior/Lighting) 37 09-13-2013 08:14 PM
Front LED Daytime Running Lights myjobis2pimp NY / NJ / CT / PA 0 04-18-2013 06:47 AM
***FR-S/BR-Z LED Daytime Running Lights 6K White*** Vicious LED Exterior Parts - The Rest 7 10-14-2012 04:38 PM
daytime running lights JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 2 06-06-2012 11:09 PM
