Old 08-02-2013, 12:44 PM   #1
Big-B
Drives: 2013 Scion FR-S Ultramarine
Tire rolling over
I wasn't sure where to post this, but this section should get the most informed answers. I wasn't racing or on a Autocross, but might as well have been with the speed I have taken this corner.
I noticed the other day what appeared to be some curb rash on my right rear tire. Odd since I haven't parallel parked or been near any curbs lately. This morning I felt it; I took a corner, on the way to work, (90 deg left hander with slight bank) and I felt the the RR tire roll over. Sure enough I cheked the tire and more scuff marks below the tread to the side wall.
I have changed the crap factory tires and wheels and have Enkei Fujin 17x7.5 with 40 mm offset and Goodyear Eagle F1 Asymmetric 2 225/45-17. I'm running at 36 psi cold and the RR has (as best I can measure) about 1.2 deg camber.
The new setup has greatly increased grip, to the point where the car is perfectly neutral without the snap oversteer that it had before.
So what do you all think? Tire pressure to low? Bad tire?
Big-B is offline   Reply With Quote
Old 08-02-2013, 12:49 PM   #2
Tire is too wide for the rim for the way you're cornering That's the real fix.
Additional fixes include more camber and some coilovers with higher spring rates.
Old 08-02-2013, 01:53 PM   #3
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I have me some Goodyear Eagle F1 Asymmetric 2s as well, but in 225/40/18s on 18x7.5s. So far I've been amazed & happy at how much stickier they are over the stock tires. I haven't quite pushed them to the limit quite yet since they so far have clung onto every turn I've thrown at them. Good to know 7.5" wide rims might be too wide (didn't think it was wide at all) in extreme cases for 225s?
mit_peid is offline   Reply With Quote
Old 08-02-2013, 02:08 PM   #4
I actually meant that the 225 was too wide for the 7.5". Technically it's in spec, but putting it on a wider wheel (8" or 8.5") will reduce this rollover, give you a larger contact patch, and improve feedback.
Old 08-02-2013, 02:28 PM   #5
mla163
Overthinking it
Drives: BRZ in CS
I don't think the section is too wide. 225 on a 7.5" is pretty square. I mean the car comes with 215s on a 7" and I don't think that's too much width. Sure, you'll get less squirm with a narrower tire on a wider wheel, but this size isn't too crazy. Maybe that tire has really weak sidewalls. I don't know, but I find it hard to believe that a tire with 3.5" of treadwall would flatten down to the wheel.
I'd bet that the tire was either very low on air, or maybe you (or someone else) curbed it parking somehow. I've done a lot of autocross with a lot of tire and wheel combos and have never heard of anyone rubbing a wheel across the pavement.
mla163 is offline   Reply With Quote
Old 08-02-2013, 02:31 PM   #6
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Add more air and see what happens.
celica73 is offline   Reply With Quote
Old 08-02-2013, 02:41 PM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by mla163 View Post
I don't know the section is too wide. 225 on a 7.5" is pretty square. I mean the car comes with 215s on a 7" and I don't think that's too much width.
you ask for opinions and you get the best answer from one of the more qualified individuals... and you're dismissing it.
why ask for help in the first place?
Old 08-02-2013, 03:27 PM   #8
Dezoris
Dezoris's Avatar
I can't believe the tire is rolling that much. Ramp up pressures in front by 2lbs.
Are you sure you are just driving it FWD and forcing too much understeer?
Old 08-02-2013, 03:29 PM   #9
mla163
Overthinking it
Drives: BRZ in CS
I'm not the OP.
I'm just giving my opinion.
Old 08-02-2013, 04:00 PM   #10
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I'm not sure, but it seems fishy to me that he's describing the stock nature of the car as having snap oversteer. The stock behavior of the car is progressive oversteer. The only snap oversteer you'll get is if you yank the wheel and floor the gas hard. And typically a grippier tire will make oversteer even snappier so the OP's description sounds backwards to me.
raul is offline   Reply With Quote
Old 08-02-2013, 04:43 PM   #11
brz7400
brz7400's Avatar
Drives: Subaru BRZ
maybe a defective tire?
you can try swapping RR and LR wheel/tires and see if the same thing happens.
brz7400 is offline   Reply With Quote
Old 08-02-2013, 07:12 PM   #12
Big-B
You're right in that the stock setup tended to be progressive oversteer, but the stock tires tended to have inconsistent grip. Once you went past their happy point, they REALLY wanted to slide. But, with the gripper tires it's hard to get the back end to step out at all. I get slight understeer, get on the gas, and she hooks up nice and neutral.
I will probably swap the tire to different corner to see if it happens again, before I mess with tire pressures. But, CSG Mike is probably correct that the wheel is too skinny. I was vacillating between 7.5" and 8" but went for the lighter weight.
Old 08-02-2013, 07:16 PM   #13
raul
Lap time enthusiast
raul's Avatar
I think CSG Mike said your tire is too wide not too narrow.
Old 08-02-2013, 07:55 PM   #14
Sorry, please let me know if I need to clarify... I was up till like 2AM last night studying datalogs, and was at my day job by 7AM this morning.
Need more coffee.
Count for the day:
1 Drive energy drink
4 shots of espresso over ice
2 20oz diet cokes
4 shots of espresso over ice (currently drinking)
I expect another iced coffee before the day ends...
Post your rolling shots! jeffsides FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 118 10-17-2014 04:57 PM
Lightning Red BRZ Rolling Shots ChandlerSwyng FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 05-07-2013 09:56 PM
fender rolling Andybui82 Northwest 0 03-30-2013 11:44 PM
Streaks down windows after rolling them down FRS TT Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-13-2012 10:09 PM
A Rolling Tour of DC...aka...my Commute sho220 Off-Topic Lounge [WARNING: NO POLITICS] 10 08-17-2012 07:20 PM
