Old 08-03-2013, 11:46 AM   #1
e92m3
Drives: Supercharged m3/ BRZ Winter beater
New BRZ owner with a question!
First off let me introduce myself,
My name is Alex and I took delivery of my BRZ 4 days ago.
This is going to be my winter / DD as I have my garage queen (e92 m3) for the weekends.
I had a few questions hopefully you guys can answer:
First off where the rear bumper meets the fender liner there are three holes to secure the bumper to the liner. My car has only the top plastic rivet in place with the two bottom holes being empty, is this the way it comes>?
Next question is about driveline noise, is it normal to hear a thud when clutching in and place the shifter into first gear? I happens if I'm at a light or when the car is stationary and I want to take off?
Lastly is it normal the engine has a slight vibration at idle?
Thanks in advance !
Alex
e92m3 is offline   Reply With Quote
Old 08-03-2013, 11:49 AM   #2
regal
Thanks in advance !
Alex
Yes the thud is normal, you can buy STI bushings that are stiffer than the stock bushings.
Yes the engine vibrates at idle.
Good luck in the snow Recommend good snow tires.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 08-03-2013, 11:51 AM   #3
Colombo
Drives: '13 BRZ
The holes are normal. I just noticed mine like that yesterday and my STi had the same thing.
Colombo is offline   Reply With Quote
Old 08-03-2013, 12:08 PM   #4
nalc
Drives: 13 BRZ Limited 6MT GBS
Holes are supposed to be that way. They exist for the installation of OEM mudflaps. If you kinda stick your finger in there and poke around, you'll see that there's nothing behind it - the fender liner has a notch cut out around the hole, so even if you wanted to put a fastener there, there wouldn't be anything for it to attach to - there's just empty space behind the hole.
nalc is offline   Reply With Quote
Old 08-03-2013, 12:10 PM   #5
e92m3
Thanks for the quick reply!
Everyone keeps telling me about tires and sand in the trunk lol, I'm sure i'll be fine!
Old 08-03-2013, 12:11 PM   #6
e92m3
Thanks, I thought the dealer had removed the bumper.... I feel better now!
Old 08-03-2013, 12:20 PM   #7
Luis_GT
They are there incase you decide to install OEM mud flaps.
Old 08-03-2013, 12:38 PM   #8
e92m3
Good to know, I'm planning on ordering the mud flaps and weather tech carpet liners this week.
Old 08-03-2013, 02:37 PM   #9
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
nice e92! and congratulations on the BRZ! As everyone stated above, all those things are normal.
Enraged21 is offline   Reply With Quote
Old 08-03-2013, 03:51 PM   #10
humfrz
Congratulations .... welcome ..... nice looking set of cars!
humfrz
Old 09-20-2014, 03:16 AM   #11
dpgfunk
Drives: 2012 E92 M3, 2013 BRZ
nice M3, you running an ESS VT1 or VT2?
dpgfunk is offline   Reply With Quote
Old 09-20-2014, 09:47 PM   #12
extrashaky
Drives: 2014 BRZ Limited
Yes. What's happening is that when you're sitting in neutral with your foot off the clutch, the input shaft of the transmission is turning. If you push in the clutch and hold it without shifting into gear, the input shaft will spin down and stop. But if you push in the clutch and immediately shift into gear, the transmission itself will stop the input shaft, and the rotational force is transmitted along the drive shaft to the differential. The clunk you're hearing is the differential absorbing that force.
The clunk doesn't hurt anything. It's just a noise. If it bothers you, just hold the clutch in a little longer before shifting into gear.
This car has so many vibrations and rattles and other noises that it's hard to tell what you mean. If you mean that it has a slightly rough or erratic idle, I get that also and consider it normal. However, there was a TSB for erratic idle as well, which involved the dealer flashing the ECU with updated firmware. Personally, unless it's really bogging down and trying to quit, I wouldn't worry about a little stumble in the idle.
Old 09-23-2014, 10:32 PM   #13
JHSurf
JHSurf's Avatar
Drives: 2015 BRZ Series.Blue
I bought my BRZ Series.Blue a week ago and have noticed after driving it a bit and getting it nice and hot I smell a distinct oder from the engine. It smells kind of like burning oil or plastic. Is this normal for the BRZ and if so does it go away after the "new" has worn off?
JHSurf is offline   Reply With Quote
Old 09-23-2014, 10:37 PM   #14
R N M
Drives: 2015 Subaru BRZ, 2018 BMW M3 CP
Also have smell sometimes and hear some noises but only when going into 2nd gear. Haven't noticed any noise when in neutral....
R N M is offline   Reply With Quote
New FRS owner! KrankthatFRS Scion FR-S / Toyota 86 GT86 General Forum 8 07-21-2013 08:40 PM
New 86 owner kioton32 Northwest 7 04-07-2013 02:30 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 03:11 PM
Tonight: I need a Portland BRZ owner and S2000 owner! DarrenDriven Northwest 2 06-19-2012 03:40 AM
