Drives: 2013 BRZ Limited
Not enough exhaust Back Pressure? Quiet car?
I just added a P&L header to my BRZ. The car's quite a bit louder than it was before when it just had a 2.5" ISIS cat-back on the car (2nd cat deleted). Actually...it's very loud now. But, the header certainly got rid of the torque valley.
Also, the car's not running as smoothly as it did...even with changing to an appropriate Unichip map to adapt the ECU to this exhaust. It was running fine for a week, but now...not so much even with a few more Unichip maps tested. I had the car at a muffler shop today to see about adding a resonator to quiet it down just a bit and get rid of a slight rasp and some drone that popped up with the new header. The shop manager said a resonator wouldn't do much and that I should consider adding a 2nd cat back (some super slim new type of high performance cat) to quiet the car, increase back pressure and make the engine run a little better. He thought there was too much 'flow.' What do you all think of this? |
I think you need a real tune. I'm not driving at all on my header until I get it tuned at the same time.
Scrape Master
Drives: Goal: Oldest FRS State Side
A resonator will remove the rasp and some drone. How is a tune going to help with rasp and drone? Also there is no proof back pressure does anything.
Drives: Subaru BRZ
#5 | |
Take Perrin for example, the resonated version is pretty quiet. The non resonated version is loud and gets raspy with a header. Have an exhaust shop fabricate a midpipe with a resonator that's smaller than the Perrin resonator but not tiny and keep the cat in the front pipe. That should do the trick. |
Drives: Mazdarati
So before catalytic convertors were mandatory how do you think we got rid of drone and rasp............hint: similar to a muffler, but called a resonator.
Then we jetted our carburetors, and changed the weights in our distributor and set the dwell and timing with a timing light................thats tuning!!!!
#7 | |
Scrape Master
Adding a high flow cat or resonator will definitely help kill some (or all) of the raspiness, but won't help it run any better.
IMO you need a proper tune for the header, that'll make it run better.
#10 |
Thanks, guys. I'll talk with Unichip Jack and see if he has any suggestions on another map that might provide a better overall tune.
I think I've decided to add a small resonator to kill a little of the rasp/drone. I appreciate the help! |
#11 | |
I still do it this way :happy0180: As they stated above, if you add a cat in there you will get rid of the rasp. and it will quite the car a bit. |
#12 |
Drives: CBS BRZ
I have the p&l header and after I had it installed the car bogged like crazy in low rpm. I sent a log to visconti and as soon as he sent me my new tune everything was fixed.
All kinds of gains....
| quiet and loud exhaust both in 1 | JonMotoring | Engine, Exhaust, Transmission | 28 | 04-24-2020 03:22 PM |
| Need a quiet exhaust setup for California | Pneub | Engine, Exhaust, Transmission | 17 | 05-29-2013 04:34 AM |
| SRT Cat-back exhaust | prest1ge | Engine, Exhaust, Bolt-Ons | 15 | 03-17-2013 03:37 PM |
| My new set of cat back exhaust | Koe | Engine, Exhaust, Transmission | 23 | 10-13-2012 07:44 AM |
| Quiet exhaust | s2kdrew | Engine, Exhaust, Transmission | 21 | 06-26-2012 12:22 AM |
