Old 08-19-2013, 01:27 PM   #1
swift996
swift996's Avatar
02 Sensor Socket Size?
I bought one and forgot what size it is...does anyone know? I have to install something that calls for a 27mm socket and that sounds right/close.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-19-2013, 01:33 PM   #2
d1ck
Drives: Black 2013 FRS
Most O2 sensors are 22mm / 7/8". I've never taken the sensor out of the twins but I'd bet that it's the same size.
d1ck is offline   Reply With Quote
Old 08-19-2013, 01:37 PM   #3
swift996
swift996's Avatar
You're correct, I do recall buying a 7/8" socket. Thanks, guess I'll run to AutoZone and pick up a 27mm socket.
Old 08-19-2013, 02:06 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Get a 6 point socket if it is for what I think it is. Apparantly it helps.
Old 08-19-2013, 02:25 PM   #5
swift996
swift996's Avatar
It's to tighten up the themostat adapter plate on my Perrin Oil cooler. I just picked up a 27mm socket at AutoZone. My socket sets only go to 19mm so anything above I forget what is what.
Old 08-19-2013, 02:26 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That is what I knew it was for. It is a very difficult nut to get the socket on due to the design of the adapter plate.
Old 08-19-2013, 10:30 PM   #7
swift996
swift996's Avatar
You were not kidding, that adapter design is not socket friendly!
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 03:20 PM
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 01:46 AM
Can't torque my lug nuts socket too shallow :( chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 07-25-2013 11:25 AM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 11:25 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 09:41 PM
