Black Blood of the Earth
Drives: The Porkchop Express
Clunking noise after installing springs
Installed RS*R Superdowns on the BRZ this weekend, and I'm getting a clunking noise all around the car in low gear at slow speeds. There are no noises at high speed on the highway, everything is smooth. After noticing the noise, we jacked the car back up and double checked everything, and nothing was loose. Drove the car all weekend hoping the noise would settle, but it hasn't. It's not better or worse, just clunky on bumpy roads and road divets, like something is loose. NOT a metal on metal sound. I'm taking it to my friend's shop this weekend to put it on a lift, and check the suspension. Has anyone else had something similar happen when lowering on springs?
It's all in the reflexes.
Do those springs have rubber spring silencers where the springs compress?
Sent from my Nexus 4 using Tapatalk 4 |
#3 | |
Time Traveller
Rear end clunk after H&R Super Sport Spring Install http://www.ft86club.com/forums/showt...ighlight=clunk Clanking sound after Eibach pro install http://www.ft86club.com/forums/showt...ighlight=clunk Suspension Review: Race Comp Yellow Springs http://www.ft86club.com/forums/showt...unk#post456900 Clunk sound from rear suspension http://www.ft86club.com/forums/showt...ighlight=clunk |
#4 | |
http://www.frs86.com/suspension/rs-r...s-for-brz.html
head of infinite swagger
Drives: 2013 FR-S 6MT
I had 2 separate noise issues when I did my springs and then LCAs 2 weeks later. The 2 culprits were the top hats (or mounts) not being tightened properly in the rear and then the sway bar end link bolt that attaches to the LCA was stripped and didn't tighten properly.
Triple check everything to make sure you have no play.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
Try the upper mount nuts - especially on front struts. People tend to think all they need to do it tighten the nut, they forget that the inner shaft will spin. So they have to hold the shaft while they torque the nut to 41lbs. Try that.
Drives: 04 Evo 8 SSL, 13 Brz Limited
Make sure to torque it to the recommended specs since I had that issue with my st coilovers
Alexandrino_Auto
Drives: series.Blue
You guys are answering a 2 year old post...
The Shadetree Project: I turn wrenches
noobs
by the way this is wrong.. most people blow their stock struts if they allow the shaft to spin while "torquing" the nut down, or trying to disassemble, or any combination of the two. |
#10 | |
I got a bad clanking from a loose upper strut nut because the dealer tech didn't torque it down to spec. |
| Tags |
| clunking, noise, springs, suspension |
| E-Brake issue "clunking noise" when pulling the e-brake while rolling. | Kinzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 06-20-2018 11:14 PM |
| Replacing Struts and Installing Coil Springs | DarrenDriven | DIY (Do-It-Yourself) Guides | 195 | 04-26-2017 05:15 PM |
| rear rattling/clunking suspension noise | ceebo | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 04-25-2014 11:00 PM |
| Transmission Clunking (A/T) | Mr. J | Issues | Warranty | Recalls / TSB | 6 | 01-01-2013 08:11 PM |
| How necessary is alignment after installing new springs? | switchlanez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 11-22-2012 12:52 PM |
